  • Dot Guests: 969
Author Topic: What size tyres?  (Read 13909 times)
Offline RugbySheep
What size tyres?
« on: May 10, 2018, 04:03:58 PM »
Hi Guys
Need a little help. We have had the old tyres taken off the original 14" rims so the rims can be powder coated. We forgot to take note of what size the tyres were that were on the rims. Our local Tyre guy needs to know what size so he can fit the right ones being mind full that we have a highway diff in our Bedford. Don't want anything low profile as its a camper and will be doing a few K's.....one day.
Reading through the forums after completing a 'tyre' search, it looks like we may need to fit 215x14 65???
PS. in the rim it has stamped 5 1/2 x 14
« Last Edit: May 10, 2018, 05:36:27 PM by RugbySheep »
Re: What size tyres?
« Reply #1 on: May 11, 2018, 01:22:06 AM »
you should check the tyre plate on the side of the seat base for the right size , usually inside the door on either side . but I would think they would be around the 185x 70x 14's on a stocky . I would consider going with light truck radials if you're hauling a bit of weight . hope tha helps .Cheers Merlin
Offline RugbySheep
« Reply #2 on: May 11, 2018, 08:16:47 AM »
Hi Merlin.
Didnt think of checking that. Definitely going light truck tyres. Cheers for the help
« Reply #3 on: May 13, 2018, 09:51:05 AM »
go with 70 or 75 profile.. thats what i had.. but 225/215 x 70 x 14" on powder coated K9 steel mags
Offline RugbySheep
« Reply #4 on: May 17, 2018, 06:57:29 PM »
Hi Guys
Cheers for the input.
We went with 185/70's. Couldn't get them in light truck tyres as they don,t come in 14's apparently.
We had the rims sandblasted as they were full of surface rust and pretty crappy. They were then primed and powdercoated in satin black. They look awesome. Well worth the $88 each to have done.
« Last Edit: May 17, 2018, 08:37:37 PM by RugbySheep »
« Reply #5 on: May 20, 2018, 08:20:01 PM »
yep happy with mine too.. been 7 years and just starting to show a little rust spots now..
Offline RugbySheep
« Reply #6 on: May 22, 2018, 09:06:25 AM »
Nice. Did you get them primed before sandblasting?
« Reply #7 on: May 22, 2018, 09:12:01 PM »
no after.. then powder coated
Offline stuuuz
« Reply #8 on: May 22, 2018, 09:47:37 PM »
I'm running original rims too. I have put both 185r14c and 195 r14c on. The C means light truck tyre. The 185r14c should be easy to find and cheap as it is a common size. The 195r14c is a little more expensive (say $90 each if you shop around) but I believe suits the van better as it is a little fatter.
Sorry it looks like you have already bought tyres but at least you have options for next time. Rims look good btw!
Offline RugbySheep
« Reply #9 on: May 26, 2018, 09:40:28 PM »
Hi stuuuz
Yeah I wish niw I had of gone with slightly wider tyres.  Stills looks ok tho. Just need to purchase some nice chrome hub caps now
