  • Dot Guests: 356
Author Topic: LIGHTS OUT, INDICATOR SWITCH WIREING PROBLEM-HELP PLEASE!!!  (Read 9843 times)
Offline Poochimama
« on: November 02, 2011, 04:49:40 PM »
Hey its pain in the ass me agaaaain,lol!!
Now im torturing my other brother Wayne this time with the electrical's,got him stumped?
When i bought my Beddy and drove it from Qld to Vic the head lights would go completely out in between flicking them from Hi to Low or visa versa,SCARY driving in the dark.
I bought a new compatible Morris Minor Indicator arm and STILL having the same probs?
My guess its something to do with the original electicals,but then again what the hell would i know,....im just the interior decorator dept chic?
OK boys,scratch ya heads or yr nutz on this one for me and give me your idea and how to solve this next problem now,im thissssssssss far away from FINALLY drivng my Muff machine,HELLLP,its killing meee! VOOM VOOM,I can hear it now!!  :'( :'( :'(
Shell (Poochi)
« Last Edit: November 02, 2011, 04:52:15 PM by Poochimama »
Offline cfjeff
Re: LIGHTS OUT, INDICATOR SWITCH WIREING PROBLEM-HELP PLEASE!!!
« Reply #1 on: November 02, 2011, 09:40:27 PM »
had similar prob recently (about the last 3 years, still no hurry eh) was the connector on the firewall not making good contact. Could also be fuses, depending on what year your van is. Also check inf anyone has added a relay to the headlight circuit, these have also been known to fail especially when fitted in engine bay.
Hope this helps
Cheers Jeff
Just customize it!
Offline Poochimama
« Reply #2 on: November 02, 2011, 10:10:05 PM »
OK, kool, thanku Jeff!
Fuses are all fine,its a 1980 van.
Also just found out the Blinkers arent working now?
Wayne will checkout what you have suggested,
Shell
aka5000
« Reply #3 on: November 03, 2011, 06:17:03 AM »
Try cleaning the contacts on your headlight switch, but also could be faulty high beam switch or wiring, I had a floor dipper wired into my indicator switch. Are they original headlights or halogen? The old Bedford wiring doesn't cope very well halogen headlights, if  they are they need to be rewired. I had headlight problems for years until I had them fully rewired with relays and fuses etc.
Alex
Offline Poochimama
« Reply #4 on: November 03, 2011, 04:22:14 PM »
They are original headlights,
Thanku Alex...ill tell wayne your info too!!! ;D
« Reply #5 on: November 03, 2011, 06:09:56 PM »
Check your earths are good and as Jeff mentioned that junction box on the fire wall can be the cause of many problems
Offline Poochimama
« Reply #6 on: November 03, 2011, 10:12:34 PM »
Thanx Kiwi,
kool..Um but wheres the junction box,inside under the dash or under the bonnet?
thanku
Offline LS120
« Reply #7 on: November 04, 2011, 04:21:06 AM »
its on the drivers side under the bonnet.. right up in the top corner .. you may need a torch to see it.. they are a rubber plug socket system..i have some infoe here some were that tell's me what one is for what as there are 3 plugs and i had to do some wire tracing a while ago.
Offline Poochimama
« Reply #8 on: November 04, 2011, 09:23:43 AM »
BRILLIANT, THANKU! ;D
Offline Poochimama
« Reply #9 on: November 05, 2011, 08:49:09 PM »
QUESTION BOYS...Do any of you know IF there is a wireing diagram for these things,it would help alot! Hes gone thru every wire for faults n still cant find the prob yet? :'(
Dont have a Beddy manual,might have to buy one huh?
THANKU
