  • Dot Guests: 460
Author Topic: I need a diff housing  (Read 19964 times)
Offline shaginwagin
  • Real Vans are BIG Vans
« on: September 28, 2010, 10:22:45 PM »
Hi guys, I have a donor VN and doing a full transplant of V6 auto and diff into Alien8.  I have to get the  holden disc brake diff widened and to do that I need a standard short wheel base diff so the diff man can get the plates for the springs in the right place.  currently running a Chev Caprice diff so I am hoping a Brisbane owner might be able to give me a LEND of a non modified standard diff for a short time.
Julian.
Julian
Re: I need a diff housing
« Reply #1 on: September 28, 2010, 10:26:48 PM »
if you get stuck someone could just cut the axle tubes off for you?
Offline weasil
« Reply #2 on: September 29, 2010, 07:36:44 AM »
I have a diff you can have . freebie . pick up on gold coast
weasil
« Reply #3 on: September 29, 2010, 10:48:16 AM »
Hey julian, mate do you have anymore pics of your van, yours seems to be in the background to alien8, love to see some pics.
Offline shaginwagin
« Reply #4 on: September 29, 2010, 09:59:55 PM »
Yes George, I do have more pics of the chev, does it matter that I don't own it any more. Have pics of the reupholstering as well.
Julian
Julian
« Reply #5 on: September 30, 2010, 08:20:46 AM »
Hey julian, no mate does not matter if you have sold it, still would'nt mind seeing it.
« Reply #6 on: September 30, 2010, 08:28:15 PM »
i have a set of axel tubes if you need pm me.
Offline shaginwagin
« Reply #7 on: September 30, 2010, 11:15:47 PM »
Thanks for the offer Ben  but I'm using the VN disc brake diff and getting the short side tube  taken out and using the long side tube from a second diff put in to get the diff within 1and half inches the original bedford diff size.  I need an original bedford diff housing so that the diff man can set the Holden diff up correctly. Will take pics so will post them up when its done.
Julian
Julian
« Reply #8 on: October 01, 2010, 12:01:54 AM »
Julian
So Julian does it use two long side axels then, and is the stud pattern HQ or crumadoor ?
Would be good to see some pics - sounds like a simple solution to the beddy diff problem
« Reply #9 on: October 01, 2010, 08:57:41 PM »
Hey Julian, You got the fuel tank out of that VN?
