  • Dot Guests: 385
Author Topic: Celica 5 speed conversion  (Read 15480 times)
Offline Marky
« on: April 17, 2009, 04:12:46 PM »
Hey Folks
Ive Just bought a Celica box off Ben.....
I wanted to know...
- The name n make of Clutch..... i have to get for my new gbox....Im running a blue 202
what modifications i have to make to gearbox crossmember?
thanks
Marky
Creative Media Producer
hammers_spanners
Re: Celica 5 speed conversion
« Reply #1 on: April 17, 2009, 05:17:12 PM »
Marky speak to your local brake and clutch people, they should be able to supply a clutch plate.
In the article below from oldholden.com it lists a 1.8 Toyota Lite Ace clutch plate should fit.
http://holdenpaedia.oldholden.com/index.php/Celica_5_Speed_into_old_Holden
Also a speedo cable from a hi lux is mentioned.
Hope this helps.
Craig
Offline Marky
« Reply #2 on: April 17, 2009, 05:22:13 PM »
Hey Craig Thanks..had a look at that...
No pics of a beddy conversion...appparently from article
 celica box is 40mm shorter and lower than m21 box
so gearbox crossmember has to be modified
im looking for pics of converted crossmember in a beddy...anyone got one in their van?
hammers_spanners
« Reply #3 on: April 17, 2009, 05:31:37 PM »
Marky I haven't done a celica but did a supra a little while ago. We had to drop the x member down by fitting 25mm x 25mm square tube between the rails and x member. Used longer bolts and you will need to fit some tube/pipe inside the square tube to stop crushing it. Tailshaft also needed modifying, the yoke and length were wrong. We turned the shifter around to face forward and fitted an extension to get the height right.
Craig
Offline Marky
« Reply #4 on: April 17, 2009, 05:39:09 PM »
nice one ..great idea  with the 25mm pipe hadn't thought of that
tht will take care of the 40mm drop needed ..now to sus the bracket that is needed to seat the bottom of box
been reading this article too on conversion into an EJ/EH
 http://forum.ejehclubqld.com/ehclub/forum/topic.asp?TOPIC_ID=6729&#45374
This guy made up brackets to fit...just need a shot of a beddy....with a 5 speed..hmmmmm
« Last Edit: April 17, 2009, 05:40:56 PM by Marky »
hammers_spanners
« Reply #5 on: April 17, 2009, 05:44:06 PM »
Marky we used the x member and re drilled the mountings for the g/box mount. The pic in your link looks good or you could use a flat plate withh the celica mounting holes on the front and holden ones at the rear.
« Reply #6 on: April 17, 2009, 06:24:34 PM »
When you guys speak of Celica boxes, what boxes are you really speaking about? T50s? W5x? Steel case?
« Reply #7 on: April 19, 2009, 09:13:52 PM »
yeh marky this gearbox comes with crossmember clutch plate. pressure plate, thrust bearing.. tail sharft yoke. you shouldnt have to buy anything else.. except maybe to get the gearbox at the right hight.
Offline Marky
« Reply #8 on: April 30, 2009, 06:20:54 PM »
Got My Box delivered...Thanx Ben
Its got a castlemaine Rod shop Bell housing.....I rang them for answers about my box..said "no info avail"
What I want to know is....The box has a forward pointing Gear Linkage.
eliminating the need to use it as a top loading gearbox
and enables
to mount it in a normal beddy selecter postion
.........with a bush..but it has no mounting for the  bush..
any one seen one these set up before?
« Last Edit: April 30, 2009, 06:22:25 PM by Marky »
« Reply #9 on: April 30, 2009, 10:21:34 PM »
thats all custom marky.. prety cool huh. yeh just got to get it all working.. post some pics up so people can help.
