  • Dot Guests: 927
Author Topic: engine replacement  (Read 34670 times)
Offline JOE RYAN
Re: engine replacement
« Reply #20 on: April 23, 2009, 07:10:52 PM »
I have never taken a motor out this way but from what I can imagine don't you have to disconnect the steering from the rack and pinion and the brake line
joe
« Reply #21 on: April 23, 2009, 07:25:05 PM »
Hey Able, send me a PM for my home phone number I am working on my beddie this weekend so if you need some tips givusa call .... Eddy
« Reply #22 on: April 23, 2009, 08:00:52 PM »
opps yep brake lines.... that could have been a bit messy (thankyou)
and yep ill send a pm to you eddy
« Reply #23 on: April 23, 2009, 09:36:01 PM »
Um not sure if it got mentioned but, fuel line and power cable to the starter.
Clutch cable, slacken of the adjuster and slip off the end of the clutch arm.
And phone Eddy - he knows it all :D
« Reply #24 on: April 24, 2009, 11:56:03 PM »
well the 186 is out...
took a few beers and a few up and downs.... (torsion bar ends catching under the wish bone) but other then that it was pretty straight forward.... after all the advice...  ;)
i have it sitting on stands that are placed under the bar/cross member that holds the back end of the gear box, is that a safe place to have them untill i paint up the front end and stick the 202 in?
« Last Edit: April 25, 2009, 12:01:36 AM by able »
« Reply #25 on: June 04, 2009, 11:16:47 AM »
i painted up the front end..... and im positioning the 202
the oil pan seems to be resting on the front end a bit....
she will be right? or wood wedge bash time?
« Reply #26 on: June 04, 2009, 01:59:35 PM »
if ur sumps touching the chassis(crossmember)  u will need to use  the right sump and pickup tube.
u will need 2 use the 186 ones.
while the motors out check the welch plugs are in good nick. brass onesare the go.
marty
« Last Edit: June 04, 2009, 02:02:56 PM by marty »
« Reply #27 on: June 04, 2009, 02:57:02 PM »
im just thowing an idea out there.
it looks like the right sump to me.
you dont have anything supporting the back of the motor. once the motor and gearbox goes in it will be supported by trany crossmember. so it will lift it up and you should have an inch clearance or something.
at the moment the motor is being supported by your engine mounts and crain yeh?
« Reply #28 on: June 04, 2009, 04:01:01 PM »
yep ben its the stock 202 sump. i have a jack (with a soft wood block) underneath the back now but not in the pic because i needed to remove the crane to lock up the garage.
the one from the 186 sat a little further back but i have just finished painting and putting new seals in the 202 and it will be a shame to have to get the kerosene out again.....
how much lift will it get when bolted up to the gear box so i can simulate with the jack?
would it hurt or buga anything if i gave it a dint in the offending area if i do not get the clearance i need?
how much clearance is enough?
do i need to put lock tight on the four chassis bolt that hold the front end in?
« Last Edit: June 04, 2009, 05:13:40 PM by able »
« Reply #29 on: June 04, 2009, 04:17:43 PM »
ask Johnno( John Abbot) for a picture of the sump he took outa his truck,
and had 2 replace with the right 1.
thats 1 way 2 fix the clearance. lol.
marty
« Last Edit: June 04, 2009, 04:19:49 PM by marty »
