  • Dot Guests: 1485
  • Dot Users: 1
  • Dot Users Online:
Author Topic: indicators stopped workinh  (Read 35765 times)
0 Members and 6 Guests are viewing this topic.
Re: indicators stopped workinh
« Reply #10 on: June 19, 2016, 10:18:51 AM »
Knowing how the "logic" of the indicators/hazard lights work, please don't think this stupid...... is the hazard switch making good contacts... this little blighter has many contacts within it, connecting the indicators when off and hazards when on.
« Reply #11 on: June 19, 2016, 04:16:07 PM »
true that rumax.. i had one play up on me once and replaced it.
Offline Hobbit
« Reply #12 on: June 20, 2016, 01:19:22 AM »
My hazards don't work, but from memory, the earth wire from the hazard switch has to contact with metal on the dash or the indicators won't function.
 Photo of broken contacts on my last indicator switch.
Offline Marky
« Reply #13 on: June 20, 2016, 11:11:58 AM »
thanks all
indicator switch is 2 months old...land rover mk1 rewired....(is what rob at bedford manor is logan sells too)
no broken wires....all else on stalk works n operates..
im still chasing it...will let ya know..when i find the indicators again lol
Creative Media Producer
« Reply #14 on: June 20, 2016, 07:47:54 PM »
Hobbit, that earth wire is so the globe in the switch flashes!
Offline Hobbit
« Reply #15 on: June 21, 2016, 07:50:16 AM »
Okay....It's crucial to the turn signal circuit though.
Offline JOE RYAN
« Reply #16 on: June 21, 2016, 05:20:38 PM »
Wire was in the middle connector top right hand corner light blue colour but I gave them all a bit of a clean as most had signs of corrosion
Offline shaginwagin
  • Real Vans are BIG Vans
« Reply #17 on: June 21, 2016, 07:39:38 PM »
The contacts in the indicator/ hi low beam, could be dirty,  ive had to clean mine on a few occassions,  a small piecee of wet and dry paper will clean them up. Not saying it is the problem but it can't hurt.  Could unplug indicator stalk, a multi metre and check that you have a full circuit, when indicator is on.  No full circut has to be in the indicator stalk.
Julian
Offline Marky
« Reply #18 on: June 22, 2016, 10:27:01 PM »
I have tried 4 spare indicator stalks... All components operational on each stalk
But no indicators working on any stalk
Offline john
« Reply #19 on: June 23, 2016, 12:58:56 AM »
you may need to look at the printed circuit at rear of instrument cluster, remove cowl and with a mirror check circuit is intact,
