  • Dot Guests: 1172
Author Topic: removing rear window seals?  (Read 5267 times)
Burkey
« on: February 18, 2009, 03:26:53 PM »
Hey Guys
I Need to remove my rear window seals to place them in a new door,
Just wondering if anyone has done this before and whats the best way to do it?
So Far i've been pretty rough with it and I'm just worried about breaking either the window or the seal...
Cheers.. Burkey
EDIT----
Never mind... Jumped the gun a little bit... Just read the post by busy on removing windscreens, which by the way was very helpful
Amazing where about 2 minutes of actually reading will get you.
« Last Edit: February 18, 2009, 03:56:18 PM by Burkey »
Re: removing rear window seals?
« Reply #1 on: February 18, 2009, 07:50:29 PM »
those windows are very strong, you'd probably break your hand before breaking the glass
The back windows can be a pain in the butt to get in, depending on the rubber condition they can be fitted with the string method or by placing the rubber into the door and working the glass into the rubber. be sure to remove filler strip before fitting
« Reply #2 on: February 18, 2009, 10:38:30 PM »
hey burkey you will probably have to cut out a little bit to get the windows to fit.. i just wanted to make sure they werent too big.
(bought a 1 piece fibreglass door off me last week..)
