  • Dot Guests: 412
Author Topic: Ignition switch  (Read 29637 times)
Re: Ignition switch
« Reply #20 on: November 21, 2015, 07:02:40 PM »
This diff has the original beddy studpattern.
Might be about a week till its blasted and painted black.
Enamel.
Re: Ignition switch
« Reply #21 on: November 25, 2015, 07:16:03 PM »
yeah if you want to keep the same bedford stud pattern a diff center chop is the way to go.
with my set up i can get a top speed of 110-112 kmh  maxed out on the flat.
Offline Drifter
    • my beddy resto
Re: Ignition switch
« Reply #22 on: November 26, 2015, 12:56:41 PM »
Thanks for the info mate - that's all the speed I need - Seems like the easiest way and not have to deal with disc break conversion for the front end.
never to old
Re: Ignition switch
« Reply #23 on: November 26, 2015, 06:41:40 PM »
I have a 3.5:1 diff in my traytop and in theory, pulls 3000 rpm for 105 km/hr. Well under max RPM.....
Offline Drifter
    • my beddy resto
Re: Ignition switch
« Reply #24 on: November 27, 2015, 05:59:50 AM »
Thanks rumax - what did you get the diff out of.?
« Last Edit: November 27, 2015, 11:10:27 AM by Marishka »
never to old
Re: Ignition switch
« Reply #25 on: November 27, 2015, 04:32:42 PM »
Would you believe from a CF in a wrecking yard. Duel wheels and all. :)
It's a chev 12 bolt.
But I do have a diff out of another van that donated parts for my restoration... single wheel B/W 3.23 diff- I think.  Tag on it said it was out of a Valiant CL??? would drop another 200 rpm @ 100
Happy to sell for the right price.. and that isn't too high.
Have a side door and pair of rear doors as well....
Located in Adelaide.....
Re: Ignition switch
« Reply #26 on: November 27, 2015, 04:33:44 PM »
I had a dream of doing another CF... but have realised I do not have the time or funds.... :(
Re: Ignition switch
« Reply #27 on: November 27, 2015, 05:49:45 PM »
yea the nice thing with the Holden center is the gear ratios are a lot so you can mix and mach to what you want.. i think mine is 3.08 : 1 was out of an HQ i think. and a lot of them around. i also have a 5 speed Holden box but the 4 speed seems ok for me.
Offline johnb44
Re: Ignition switch
« Reply #28 on: November 27, 2015, 09:53:13 PM »
im having a ford 9inch fitted at the moment with a 3.0 ratio centre as the one I had was very a bodgy set up and the ratio was 2.75 which was just a touch to tall , I should get pinky back next week and am very interested to see what difference it makes as 100kph was 1500 revs with the auto lock up switch on, should have a bit more go and still get reasonable economy
Offline Drifter
    • my beddy resto
Re: Ignition switch
« Reply #29 on: November 28, 2015, 07:02:06 AM »
thanks fellas - the fog is clearing - I really appreciate the input...
I can get my head around everything else but the diff had me stumped...I'm sure I had a diff from a hq in my old one..but my memory of it is to fuzzy.......but I remember it was narrow and I had to have the wheels reversed to get it looking right - and I ended up with two spare wheels,  which I don't want  trying to get it right this time around...
Rumax I think Adelaide is a bit to far from Huskisson - seems everyone is a long way from Huskisson..
never to old
