  • Dot Guests: 1643
Author Topic: WANTED SPEEDY CHEETAH...SUIT COMMODORE 5X120 PCD.  (Read 14723 times)
« on: May 20, 2015, 07:58:19 PM »
AFTER SPEEDY CHEETAH FOR MY BEDFORD..
18x9..not made anymore....
19x9
or 19x10
any one know of any please let me know...
prefer perth.....
Re: WANTED SPEEDY CHEETAH...SUIT COMMODORE 5X120 PCD.
« Reply #1 on: June 17, 2015, 03:26:06 PM »
anyone??????
Offline Bean
« Reply #2 on: June 19, 2015, 07:24:56 PM »
I saw a set lying in the back of a tyre shop today, they are BMW rims ,not sure if the stud pattern is 5x120.but the cast looks identical to the ones you're after
Check it out and let me know
Offline 6pac
« Reply #3 on: June 23, 2015, 10:50:24 AM »
Felllas
BMW and Commodore are 5/120 stud pattern, you just need to check the back spacing of the wheels.
They will fit on HQ stud pattern,very snug fit, but they do not seat properly and you will have balance/wobble problems.
Hope this helps
Rhett
« Reply #4 on: June 23, 2015, 04:41:55 PM »
HQ and Commodore are not the same size, there is like .6mm difference in the size and I have heard this can lead to snapping wheel studs, I would not recommend anyone try this!
Offline 6pac
« Reply #5 on: June 23, 2015, 04:52:38 PM »
yes you are correct.
from memory HQ are 5/114.3???
I was not recommending them, just added it as some people fit them because they can do them up.
I was hi lighting the issues this creates.
Rhett
Offline Rogerfied
« Reply #6 on: June 23, 2015, 07:34:36 PM »
PCD Sizes
120.65 is HQ
120.00 is Commodore
114.3 is Ford
You can get hub concentric adapters on E BAY to fit after market wheels to various hub centers, these fitted correctly puts the vehicle sheer load on the hub as required now and takes sheer load off the wheel studs.
Most pressed steel rims as HQ / Ford etc were not that accurate from the factory but mag wheels are accurate as most CNC machined now.
cheers Rogerfied
« Last Edit: June 23, 2015, 07:51:48 PM by Rogerfied »
Jigsaw one piece at a time
« Reply #7 on: July 28, 2015, 04:56:51 PM »
found 18x9 like I wanted...
