  • Dot Guests: 1200
Author Topic: Givin the van a tickle  (Read 88568 times)
Offline phill
Re: Givin the van a tickle
« Reply #40 on: July 02, 2016, 09:21:11 AM »
OK so I got the caliper plate sorted the boys at work machined one face on the plate to ensure the caliper mounts square with the stub after oxy cuttig, they also did a bit more machining on the in-err side of the hub so it doesn't foul on the caliper plate, and so the bedford bearing seal fit's into the Vn hub.
Phil
Offline phill
« Reply #41 on: July 02, 2016, 09:42:54 AM »
few more pics, I'm pretty happy with were the pads sit on the disc after a bit of head scratching haha
Phil
« Reply #42 on: July 04, 2016, 01:06:06 PM »
looking good phil!
Offline phill
« Reply #43 on: July 04, 2016, 07:18:37 PM »
Cheers Sammy
couple of pics here, once I was happy with how much I'd ground off the the stub axle,Thanks again Sammy for the info, I made a pattern of it to grind the same amount off the other side
Phil
« Reply #44 on: July 05, 2016, 01:42:20 PM »
thats a good comparison, i knew i ground 1-2mm off but didn't really have any way to visually see the before and after!
« Reply #45 on: August 19, 2016, 05:56:16 PM »
what harness ae you using to get the buick running.......v6 conversions or your own...
Offline phill
« Reply #46 on: August 20, 2016, 10:17:13 AM »
I'm using the complete vn loom out of the donna car, that's why I changed the dash using the vn instruments so it all plugs straight back in, I'm trying to keep cost's down and use what I already have pretty mush all vn ruining gear into the Bedford
Phil
Offline shaginwagin
  • Real Vans are BIG Vans
« Reply #47 on: June 18, 2017, 12:23:21 PM »
Hi Phill,
I used all the vn loom wiring  made it easy for all the switches and instruments to match in, cluster just plugs in.  Had to extend some wires and shorten others but everything works.   Having said that I like and used  the vs dash and cluster as well as the steering column,. Vs also plugs straight in to the same 3 plugs of vn BUT THE WIRING IS DIFFERENT. There are 3 or 4 earth and power wires that are different and the cluster will start to smoke,. 😖  Yes found that out first hand, fortunately not to mutch damage 😀     only have to work out the headlight and wiper wires to get everything working correctly.  The wiper plug fits the beddie wipers and it works on slow/fast/ intermittent.
Keep up the good work so far.
Julian
Julian
Offline phill
« Reply #48 on: June 19, 2017, 06:40:58 PM »
thanks Julian
yes I'm no auto electrician that why I'm using the vn loom it should all just plug back into it's self, I used the vn
steering column, will post some pics soon
Phil
Offline vh304
« Reply #49 on: September 24, 2017, 07:33:38 AM »
looks good mate love the progress pics
if its to loud your to old
