  • Dot Guests: 388
Author Topic: 1978 cf ignition barrel and key  (Read 7509 times)
Offline Fat bed
« on: June 09, 2014, 02:56:33 PM »
if any one has a barrel and key to fit a cf 78 model..  Or does any one know of any other type that will fit...  willing to pick up from the melbourne area
Luigi is part of our family....you mess with it you mess with us all.
Re: 1978 cf ignition barrel and key
« Reply #1 on: June 09, 2014, 04:35:50 PM »
Hi fat bed. look in the forum under Miscellaneous Technical... there is a whole thread on this
 http://www.buga.com.au/index.php?option=com_smf&Itemid=2&topic=7109.0
Offline joshua
  • aghh finally on the road
« Reply #2 on: June 09, 2014, 05:15:33 PM »
Hey there I have one for a 1979 which should be fine.
Im in yarra ranges happy to sell for $20
Offline Fat bed
« Reply #3 on: June 14, 2014, 01:01:40 PM »
Hi josh thanks ill take it give me a call on 0423485766..
Thanks rumax ill have a read
Offline Fat bed
« Reply #4 on: June 14, 2014, 02:51:14 PM »
Guys after reading the link and looking into it I have found it is the ignition switch that goes into the back of the key system.. black round bit.. josh if you have one of those that is working id be happy to buy it off you as well as the barrel
Offline vanpyre
    • Fairlanes and custom vans
« Reply #5 on: June 15, 2014, 11:24:28 AM »
you can run in dash unit from narva its a plug and play  4 point switch barrel and key all in one  part number 64018   universal fittment
Offline joshua
« Reply #6 on: June 18, 2014, 05:59:05 PM »
sorry mate ive just moved house and the bedford has now gone to the grave. just got internet back on.
Offline Fat bed
« Reply #7 on: June 20, 2014, 12:11:29 PM »
Thanks josh.. went to look at 2 wreaks today and both had same problem.. and went with new ignition mods so look like its a common problem
