  • Dot Guests: 1441
Author Topic: Shifter linkage  (Read 17916 times)
Shifter linkage
« on: January 08, 2009, 07:13:08 AM »
Hi all,
I got the aussie running gear in my standard van (3.3 and trimatic), I was told the trans used the original bedford mounts - it didn't, and was told the bedford auto shifter goes straight in - it doesn't.
Rather than reinvent the wheel, is anyone able to take some photos of the shifter linkage if you have a standard CF shifter on a trimatic box, also the trans mount mounting points on the body.
Much appreciated
Re: Shifter linkage
« Reply #1 on: January 08, 2009, 03:14:10 PM »
Busy, busy, busy...
You know better than that. Nothing ever bolts straight up. You of all people know that.  ;D
We actually found it easier to convert the trimatic to a cable shift on mine especially as it was mid-mounted, and I used a Toyota Celica shifter. Really nice shifter too.
I've pulled all the running gear out of mine now but I still have the bits that we used to do the conversion. I can take photos if you like so you can see what was done. I then had a cable made up to connect everything by Melbar Engineering down here. They specialise in making up automotive cables and do a damn good job too!
Re: Shifter linkage
« Reply #2 on: January 08, 2009, 06:11:12 PM »
I thought of a cable but because the shifter is straight above the selector I'd have to do a S shape.
the front beam is factory OZ
Tell you what, this standard van is more of a pain in the butt than the custom
Re: Shifter linkage
« Reply #3 on: January 08, 2009, 06:35:50 PM »
Ok Busy, will take some photo's and upload tomorrow for you.
Offline waikatostocky
Re: Shifter linkage
« Reply #4 on: January 08, 2009, 07:11:39 PM »
ive got a jap shifter onto a trimatic in mine and mine is pretty strait forword mate i will take some shots of it 2moro and post for ya to if you like.
Cheers paddy
be safe out there
Re: Shifter linkage
« Reply #5 on: January 09, 2009, 05:06:30 AM »
trying to keep the original beddie shifter if I can
I have to stop spending money on this van, 250 for new front tryes, 200 for locks reco'd, 350 for trans rebuild ...
Offline westy12
Re: Shifter linkage
« Reply #6 on: January 10, 2009, 09:24:34 AM »
gday busy i have that set up heres the pics hope they work let me know if you need a different angle..
Re: Shifter linkage
« Reply #7 on: January 10, 2009, 06:24:47 PM »
Hi Busy, sorry for late photo's been (busy). Will load photo's by them self if they do not load to a good size to view, this is on my van before I changed it to the overdive unit, it is factory setup for Trimatic and Holden 202 with CF shifter. The connecting rod is 20.5 cm long. Crossmember is also standard factory with the Trimatic. Hope this helps. Will have colour code for wires for factor 202 Cf tomorrow as soon as I find the book.
Re: Shifter linkage
« Reply #8 on: January 11, 2009, 11:07:51 AM »
Shame you're not local to Wellington. Was at the local pick-a-part this morning and they have a jumbo in there with a 186 conversion. I thought it was factory till I noticed the floor had been cut back a bit. The engine mounts look factory installed which is what threw me.
It uses the standard CF shifter but there is a really tricky linkage system that crosses under the floor and utilises a shifting point on the passenger side of the Trimatic.
Re: Shifter linkage
« Reply #9 on: January 11, 2009, 12:16:16 PM »
Sounds like the system you looked at was a trimatic with overdrive on it as they exit on the left hand side of the box.
