  • Dot Guests: 867
Author Topic: Shifter linkage  (Read 17883 times)
Re: Shifter linkage
« Reply #30 on: September 28, 2009, 09:14:42 PM »
as soon as i get the linkages from ben i will post some pics. before and after install.
hopefully cfjeff can get pics from the club secretary as well. looks like they are needed.
Re: Shifter linkage
« Reply #31 on: September 29, 2009, 10:46:40 AM »
With the M20 you can put the 4 speed speco shifter in the same place as the original 3 speeder use the 3 speed linkages on the forward gears, and one of the four speed linkages for reverse (this is assuming you are using a 4 spped speco from a HQ-WB) requires a little bit of modifying to get it all working - but its not rocket science.
Re: Shifter linkage
« Reply #32 on: September 29, 2009, 02:29:25 PM »
those pics would be handy warren.
Re: Shifter linkage
« Reply #33 on: September 29, 2009, 04:58:13 PM »
If I can get away from work before dark Ill take some
Re: Shifter linkage
« Reply #34 on: September 29, 2009, 07:35:16 PM »
at your leisure mate. some time this week is more then appreciated.
Re: Shifter linkage
« Reply #35 on: September 29, 2009, 11:36:53 PM »
Have a look in my gallery there in there now
Re: Shifter linkage
« Reply #36 on: September 30, 2009, 01:41:45 PM »
thanks again warren. im waiting on the pre bent linkages from ben.
