  • Dot Guests: 1559
Author Topic: Where is Rod from Bedford Bits  (Read 12008 times)
Re: Where is Rod from Bedford Bits
« Reply #10 on: April 16, 2009, 08:15:43 AM »
where you from man?
i can help you out with both those.. actually id better just check the doors o have there have no rust in them but im pretty sure they are micky mouse..
Offline Rubber Bedford
« Reply #11 on: April 16, 2009, 11:00:23 AM »
Melbourne, Northern Suburbs. If you are in Victoria too I would be keen to come say hi and check out your vans/shop/workshop.
Rubber
« Reply #12 on: April 16, 2009, 12:13:18 PM »
i work outside bro hehehe.. but i do have 9 beddies at the moment.. (bit of overkill)
yeh sure id be keen to catch up.. check out where yarram is on whereis..
i also travel to melb every weekend if you need parts i can bring them up for ya.
hammers_spanners
« Reply #13 on: April 16, 2009, 12:25:16 PM »
Hey Rubber I'm in Epping, you can have Ben drop off anything you need here if you like.
Craig
« Reply #14 on: April 16, 2009, 02:02:35 PM »
Thanks Craig, that's mighty big of you.
Ben, these three shots show a sample of the problem areas of all of my doors (sandblasted here). I expect that everyone's doors will look something like this - with rusted holes right the way through, down the bottom. If you have some that have the lower panel in better condition than these, I would be seriously interested to buy them.
http://www.geocities.com/malencontreaux/inside-left-rear.jpg
http://www.geocities.com/malencontreaux/left-rear.jpg
http://www.geocities.com/malencontreaux/passenger.jpg
I also would like a left-side vertical support post as seen missing here, removed when the side-rear window was installed. Infact, I'd like the missing panel as well, and the horizontal support bar. All in one from a wreck, I suppose:
http://www.geocities.com/malencontreaux/bedfordsplits.jpg
Yarram sure is a way away.  ;)
Rubber
« Reply #15 on: September 03, 2009, 09:22:15 PM »
Hi Ben, do you have a wreck that I could buy the left rear window panel from?
Rubber
« Reply #16 on: September 03, 2009, 09:25:57 PM »
yes
« Reply #17 on: September 03, 2009, 09:33:58 PM »
Would I be right in guessing I should come out to Yarram to cut it out myself? I would be perfectly happy if you were to do it. Craig once offered to drive parts I need closer to Melb. Anyway, perhaps I should call you to arrange something, find out cost etc
Rubber
« Reply #18 on: September 03, 2009, 11:09:41 PM »
Yes  ;D
« Reply #19 on: September 04, 2009, 07:39:25 AM »
sure thing rubber bedford.
ill pm you.
