  • Dot Guests: 406
Author Topic: locking fuel cap  (Read 27074 times)
Re: locking fuel cap
« Reply #20 on: August 23, 2014, 09:44:46 AM »
Howdy all, sorry for delayed update been soo busy it sucks...still haven't touched the shorty for 9/10 months now, it's killing me......
I was successful to get the SL17 cap to fit, however it did take a bit to do so....and luckily I had / used a dent puller to lift or raise the inside edge a smidge just enough for the internal locking tabs to bight,  the SL 17 by the sounds of it is not a perfect fit or a replacement part as it does require a bit of manipulating, and if your not handy or have a repco in your shed , you will be up against it....I just thought the make shift cap someone had used prior had squeezed my fuel neck somehow, I'll take some pics today..
Offline Bedford Fever
« Reply #21 on: August 23, 2014, 08:20:06 PM »
     Got your PM Hobbit , thank you . I thought hellelujah ran to my cap then ran to my van and tried your method to no avail .
     As hard as l tried it would not lock . As Dano just said , i do believe with some form of manipulation it could fit . So close yet so far.
     I bought the cap from epay , the one mentioned in Hobbits last post .
     Looking forward your photos Dano .
     Cheers FRank
Offline Hobbit
« Reply #22 on: August 24, 2014, 09:18:54 AM »
Sorry that didn't work for you, FRank.
According to the CPC vehicle chart, the SL17 cap was for all early models, and the SL41EC from '75 on.
This info used to be printed on the packaging.
These CPC caps should be a perfect retrofit, mine was. The locking tabs of your new cap should measure the same distance apart
as the tabs on your original.
I've used one of these SL41EC caps from the early 80s and only recently replaced it with another, after the stainless plate outer started looking a little bit warped. (Time warped)
« Last Edit: August 24, 2014, 09:57:37 AM by Hobbit »
Offline GARRY
« Reply #23 on: August 25, 2014, 06:25:03 PM »
Just had the same problem the SL17 goes on and nearly fits, so i went to plan B and put one of these on.
« Reply #24 on: September 08, 2014, 10:38:47 AM »
Here's those photo;s promised, It fits , but as with everything a little modification was required, I think and hope someone had squished the filler neck prior...I'd hate to think that these "replacement parts"  are as is?
« Last Edit: September 08, 2014, 10:41:59 AM by Dano »
« Reply #25 on: September 08, 2014, 10:46:59 AM »
Buga, well done Garry, that's the one Iv'e got for my shorty, I think mine was an Earl's from memory cost me the bomb ...years ago, it's buried somewhere in the jewlery box...out in the shed lol did you fit a breather?
Offline GARRY
« Reply #26 on: September 10, 2014, 09:34:31 AM »
Hey DANO i bought a wb filler neck with a breather pipe & some 50mm & 13mm, fuel hose to fit them, relocated it to the rear guard for the new tank.
