  • Dot Guests: 1699
Author Topic: dash  (Read 5095 times)
Offline Jimi
dash
« on: October 11, 2013, 09:10:42 PM »
How to installs custom cab dash ,with original cluster,do you remove from steel frame ,or cut the four bolts off to move back.???or something else.
Re: dash
« Reply #1 on: October 12, 2013, 09:20:17 AM »
You have to remove the front and rear of the original dash then screw the panel to the back of the CustomCab Dash - pretty easy job really, the hardest part is cutting out the hole in the Custom Dash to make it look sort of original.
Hope this helps
Mezz
http://www.buga.com.au/index.php?option=com_gallery2&Itemid=8&g2_itemId=45427
Re: dash
« Reply #2 on: October 12, 2013, 04:21:06 PM »
Have the fitting instructions here somewhere, could scan and upload if needed.
