  • Dot Guests: 763
Author Topic: My Interior  (Read 15999 times)
Offline Hobbit
My Interior
« on: April 08, 2013, 04:46:39 PM »
                                        A DARK LITTLE DEN
Pic1.
I bought sheets of 5mm, 10mm & 20mm thick 'Formshield' from Clark Rubber. It's an Aluminium
Foil laminated Polyethylene (PE) closed cell foam, which is perfect for insulating and soundproofing
a Bedford van. The 5mm, with self adhesive, was used under the engine cowl.  It's fire resistant
too. (Around $20 for 1m)
Pic2.
To retain maximum cargo space, I went with the exposed beam look. I like practicality. The visible pillars etc. were painted with 1 pack epoxy etch primer, multipurpose UC, and acrylic lacquer. For max. headroom, the roof lining is only a single layer of marine carpet. I glued the aluminium side of the 20mm PE to the walls between the horizontal body bracing, then glued strips of the 10mm PE in these gaps to create a flush surface for carpeting.
Pic3.
The 20mm foam is easily cut and fits nicely in the channels, and around the back corners. After
covering with marine carpet, trimming mostly a matter of leaving 15-20mm extra material and
simply tucking it in.
Pic4.
Although I considered using 'Weathertex', for less weight I cut a 6mm marine ply floor and sealed it
with three coats of paint.
Pic5.
With an underlay sheet of 3mm open cell PE packing foam, and then............THE NEW CARPET !!!
Re: My Interior
« Reply #1 on: April 08, 2013, 05:05:30 PM »
Looks great Hobbit I will go to Clark Rubber tomorrow & get some of that 5mm for under my engine cover The original just falls to pieces Great info Cheers Reid
Re: My Interior
« Reply #2 on: April 08, 2013, 05:13:27 PM »
Looks very tidy and clean. Well done.
Re: My Interior
« Reply #3 on: April 08, 2013, 05:23:02 PM »
WOW
Re: My Interior
« Reply #4 on: April 08, 2013, 05:39:52 PM »
When you coming to NZ ? I have 2 vans for you to do
Offline Hobbit
Re: My Interior
« Reply #5 on: April 09, 2013, 03:54:14 AM »
The last thing NZ needs right now is another hobbit.  ::)
Re: My Interior
« Reply #6 on: April 09, 2013, 07:11:48 AM »
LOL now THATS funny!  :D
Re: My Interior
« Reply #7 on: April 09, 2013, 08:45:40 AM »
That brings it up a treat i must say  :) :)  Good job Hobbit ;D
Offline VanWolf
Re: My Interior
« Reply #8 on: April 09, 2013, 09:57:29 AM »
Looks like a professional job. Well done. ;)
Offline Hobbit
Re: My Interior
« Reply #9 on: April 09, 2013, 01:11:52 PM »
THANKS GUYS,
From experience, it's better to do a proper job yourself than pay someone else to do a half-arsed job.
