  • Dot Guests: 631
Author Topic: Engine Compartment Temperature  (Read 16357 times)
Offline Joel Oswald
Re: Engine Compartment Temperature
« Reply #10 on: October 22, 2008, 01:11:47 PM »
Howdy,
The Dynmat costs approx in NZ $390 for the Bulk Kit which contains Nine 18" x 32" pieces of Dynamat Xtreme... You can buy it in smaller sized kits, i.e. door kits, trunk kits etc.
From memory I used 2 x Bulk kits & about 4 trunk kits, which are 5 pieces in each. Worked out slightly cheaper.
Joel
doofhard
« Reply #11 on: October 22, 2008, 01:20:10 PM »
Joel you must be getting sick of playing with that Bedford, maybe you should give it to me ;D
Tweaker
« Reply #12 on: October 22, 2008, 01:26:45 PM »
hey Joel
I know that you've got your starting battery in the front, but is there anychance you could post a pick of your starter motor wired up for me? The rest of your van looks awesome so I suspect it will here also. I've been banging my head against the floor of the van trying to find a new route that I'm happy with.
« Reply #13 on: October 22, 2008, 02:14:25 PM »
 ;D :D ;D :D
line up your behind me..lol
doofhard
« Reply #14 on: October 22, 2008, 03:18:59 PM »
Hey i'm in Melbourne so it may as well have a bit of a play on it's way ;D ;D ;D
Offline Joel Oswald
« Reply #15 on: October 23, 2008, 09:16:06 AM »
Not getting sick of it yet Fellas... Though I wanna be able to drive the bloody thing... Getting there though. Dash/IGN Wiring is about 60-70% complete...!
Tweaker, I can do that. I'll have a look though my progress photos so far to see if there's anything that show the starter motor & the cable leading to it. I basicaly have the thicker cable going through a hole up the front, down on the lip of the front subframe itself, using P clips riveted on.
I'll take a photo if I can't find one.
Joel
Offline Joel Oswald
« Reply #16 on: October 23, 2008, 10:13:26 AM »
I have added some photo's to my gallery for you Tweaker.... Last 6 photos. Some of them aren't great, but you should get the idea of what I did.
Shows the route of the main pos+ cable along the lower lip of the subframe. The earth cable is one of the last few shots, 86, shows where that goes. I also have another earth cable from the back of the trans to the drive shaft loop/body underneath...
Joel
Tweaker
« Reply #17 on: October 23, 2008, 10:44:49 AM »
Cheers Joel your a champ! ;) I'll check em out now. 8)
