  • Dot Guests: 807
Author Topic: bedford parts  (Read 13851 times)
Offline Rotti
Re: bedford parts
« Reply #10 on: January 02, 2013, 08:40:15 PM »
cool, is there a part number on that packet, its a PBR part, may be able to track one.... ???
Offline AndrewOC
Re: bedford parts
« Reply #11 on: January 02, 2013, 08:43:25 PM »
Is the PBR number; PR6449 or PR1175 ?
Andrew.
Offline Vandee
Re: bedford parts
« Reply #12 on: January 03, 2013, 05:26:31 AM »
Have checked part number, this number will no longer fit, as outside dia is to small, the guy said the specs changed 4 years ago and new seal was restocked as muti seal, he said the inside dia is the same at 1 1/4" mine is approx 2-3mm wider than same part number that is now stocked. No - TC1607 I checked mine when I had the diff apart, and it fitted perfect.
Offline Rotti
Re: bedford parts
« Reply #13 on: January 03, 2013, 09:22:20 AM »
cheers for that, will pound the pavement today armed with a bit more knowledge :D
see how we go!
Offline Rotti
Re: bedford parts
« Reply #14 on: January 04, 2013, 07:12:25 PM »
Done, bit of a drama. Discontinued seal, the original seal is 5mm deeper than the replacement, could run 2 seals back to back, but may be too thick? I am trying a single seal, see how she travels...I have a pic of the diff & the old & new seals
Thanks for the help guys ;D
by the way, what is this diff known as?....
Offline Vandee
Re: bedford parts
« Reply #15 on: January 04, 2013, 09:04:01 PM »
Depth is not an issue, inside dia and outside dia is all that matters. Diff in my words is a Standard 9" drum Bedford diff.
« Last Edit: January 04, 2013, 09:11:48 PM by Vandee »
Re: bedford parts
« Reply #16 on: January 05, 2013, 09:50:51 AM »
Depth is not an issue, inside dia and outside dia is all that matters   ::) ::) The wife rekons thats crape
Offline Vandee
Re: bedford parts
« Reply #17 on: January 05, 2013, 03:24:22 PM »
Would have to see the wife first to know if this is true or not.
« Last Edit: January 05, 2013, 03:36:27 PM by Vandee »
Offline Rotti
Re: bedford parts
« Reply #18 on: January 05, 2013, 03:42:24 PM »
your right, your mrs told me that this morning...BOOYAH! :P ;) ;D
Offline Rotti
Re: bedford parts
« Reply #19 on: January 12, 2013, 12:37:30 PM »
update...done, i fit the seal with the flat side in, still leaked around shaft, so put another one in flat side out, so far so good....
