  • Dot Guests: 542
Author Topic: Engine mounts  (Read 8162 times)
Offline Postie Bob
Engine mounts
« on: December 03, 2012, 05:47:34 PM »
Hi All.
While I was crawling around under my Bedmobile ( checking out the clutch ) I noticed the engine sump is hard up against the crossmember  :o .
The engine mounts don,t look too bad but should there be some sort of spacer or something under them to give the engine some clearance?
I,ve got a 186 motor in the `ol girl .
Have other peoples had this Prob???
Cheers , Bob.
Re: Engine mounts
« Reply #1 on: December 03, 2012, 05:52:33 PM »
Is it the side of the sump hitting or the sump hitting on back of cross member?
if it's the first i'd say broken engine mount (jack your engine up to see if it parts (just jack a little)
if it's hitting the back of the beam check your gearbox/trans mount, laying on your back you should be able to lift the tail shaft of the box up, or use the jack again to gently jack to see if it will seperate
Re: Engine mounts
« Reply #2 on: December 03, 2012, 05:59:51 PM »
Check the rubbers in the structs that go from the chassis to the xmember If they are shot the xmember moves back & hits the sump
Offline hammondo
Re: Engine mounts
« Reply #3 on: December 03, 2012, 09:58:44 PM »
maybe it has the wrong sump pan????
got a photo?
Offline Postie Bob
Re: Engine mounts
« Reply #4 on: December 04, 2012, 02:29:34 PM »
Had another look at my mounts and they seem ok .
I noticed that the engine mounts are attached to the front side of the mounting bracket on the motor . If I swap them to the back side of bracket it will give me a little room . However , the gearbox mount is as far back as it can go in the elongated holes in the crossmember .
This little project is getting to be a real can`o`worms  :-\
 C:\Users\pirie\Pictures\bedford sump\DSCF1079.JPG
Offline Vandee
« Last Edit: December 04, 2012, 05:20:42 PM by Vandee »
Offline Postie Bob
Re: Engine mounts
« Reply #6 on: December 04, 2012, 05:22:38 PM »
What a bummer!!!!!
I dont really want to take the engine out just yet.
I need to build a shed around the beast first.
Would the different sump alter the quantity of oil needed?
Re: Engine mounts
« Reply #7 on: December 04, 2012, 06:50:19 PM »
My sump hit also I replaced the engine mounts & gearbox mount Didnt help So I replaised the rubbers on the 2 side struts & adjusted them out & got plenty off clearance You will finde that wen you hit the brakes the xmember moves back & hits the sump Im sure that the sump is standard Just check thoes 2 rods Ill bet there loose Cheers Reid
Offline hammondo
Re: Engine mounts
« Reply #8 on: December 04, 2012, 08:33:16 PM »
I have a spare sump if you need it
I just ditched the 6
Re: Engine mounts
« Reply #9 on: December 05, 2012, 07:21:56 AM »
Postie Bob  you have the wrong sump. it just fits but if your taking it through a roadworrthy the roadworthy man probably wont like the clearance and make you change to the eh/lj sump. which are pretty rare but are standard for bedfords.. you dont have to pull the engine out to change the sump but you will need to jack engine up and cut the sump out because the clearance to too fine to get it out without cutting it. then put the correct sump in and you'll be sweet. (ive had this problem before)
