  • Dot Guests: 1293
Author Topic: Camper Update  (Read 285575 times)
Re: Camper Update
« Reply #280 on: March 23, 2012, 05:38:44 PM »
brilliant idea restoreid
that looks a better idea than lifting the body off the front chassis.
cool idea with the length of wood as a leverage assistant.
Re: Camper Update
« Reply #281 on: March 23, 2012, 06:07:21 PM »
Yeah you gotta come up with new ideas all the time when you have to doo these things by yourself It worked out real easy Cheers Reid
Re: Camper Update
« Reply #282 on: April 03, 2012, 04:42:06 PM »
well guys here's Goldfinger almost ready to go back in just have to do some welding to the extractors & modify the inlet manifold & she's ready to go Hope its a good one
Re: Camper Update
« Reply #283 on: April 03, 2012, 04:49:56 PM »
A bit of usless info for thoes still with the holden 6 in Check that someone hasent used the bottom of the sump to jack up the van If it's dinted its probably hard up against the oil pickup if it is there isnt much gap left for the oil to get through & you mite not be getting enough volume of oil through I think that's what was wrong with mine Cheers Reid
Re: Camper Update
« Reply #284 on: April 05, 2012, 04:57:05 PM »
Well guys had a good day today got the big bit in the engine bay All went smoothly As you can see from the 1st photo my helper Vessa Block is down the 3x2 half way as the lift point is above No2 cylinder I get it in as far as I can then set it down on blocks of wood & move the lift point to above No1 cylinder & have to move my helper right out to the end fo the 3x2 & employ another helper Tiney Anville to counter balence It all went great & I didnt have to share my beer with the help
Re: Camper Update
« Reply #285 on: April 05, 2012, 04:58:44 PM »
Some more
Re: Camper Update
« Reply #286 on: April 20, 2012, 03:56:08 PM »
Hi guys me again Slowly getting it back togeather These are the 2 manifolds I am going to try one with the standard varyjet carby & one with a Falcon weber on it
Re: Camper Update
« Reply #287 on: April 20, 2012, 03:59:34 PM »
The 1st one has had all the polution crap cut off & smoothed up & all holes blocked now it fits without cutting the floor & ready for paint
Re: Camper Update
« Reply #288 on: April 20, 2012, 04:01:10 PM »
Painted & installed Getting close now
Offline Jock
Re: Camper Update
« Reply #289 on: April 22, 2012, 05:43:38 PM »
Well guys got a bit more done this week Got my brandnew gear reduction starter motor $150
Reid,
Where did you get the starter motor? Do you have a part number or something that I can use to track one down?
I know it gets HOT under the engine cover and I know the starter motors fatigue because they sit so close to the extractors. Once I get my gear reduction starter motor and install it I am going to make a heat shield to protect it from the heat coming off the extractors.
Jock
