  • Dot Guests: 1557
Author Topic: Camper Update  (Read 285720 times)
Re: Camper Update
« Reply #170 on: January 29, 2011, 07:16:29 AM »
With my standard CF, is running 3.8 commodore engine and I used the commodore diff centre, is 3.08 ratio, commodores came out with 15's but I'm only running 14's (70 series tyres) I can still cruise at 100k under 2000rpm, coasting on the flats is about 1750 rpm
Re: Camper Update
« Reply #171 on: January 29, 2011, 12:42:48 PM »
hey ya all, I got a bedford diff, borg warner centre highway cruising was behind a v8 so plenty strong enough, needs centre replaced and usual brakes renewed, want it? come and get it  ;D before it goes on ebay
Offline Hippo
  • 1977 CF LWB Motorhome
Re: Camper Update
« Reply #172 on: January 29, 2011, 01:25:41 PM »
Eddy, phone number or email me direct with same please.
Re: Camper Update
« Reply #173 on: February 12, 2011, 04:03:40 PM »
Well guys have had a couple off good weeks finally got the diff in & running a lot of fiddling but it all worked out great Here's some photos
Re: Camper Update
« Reply #174 on: February 12, 2011, 04:06:36 PM »
Had to make up 2 new brake pipes Short one to connect from orignal to flexable pipe
Re: Camper Update
« Reply #175 on: February 12, 2011, 04:14:01 PM »
Had 2 make 2 new brake lines short one to join orignal beddie 2 Comm flexi pipe Driveshaft bolted streight in
« Last Edit: February 12, 2011, 04:20:18 PM by restoreid »
Re: Camper Update
« Reply #176 on: February 12, 2011, 04:23:09 PM »
Some more
Re: Camper Update
« Reply #177 on: February 12, 2011, 04:25:59 PM »
Had 2 move flexi pipe over so it wouldnt pull tight when jacked up
Re: Camper Update
« Reply #178 on: February 12, 2011, 04:28:14 PM »
Could put 10 inch wheels under there & still be under guards
Re: Camper Update
« Reply #179 on: February 12, 2011, 04:31:12 PM »
well that's about all for now have turned it round in the shead & have started on the front brakes hope to have them finished by the end of the month Cheers Reid
