  • Dot Guests: 1202
Author Topic: Camper Update  (Read 285941 times)
Re: Camper Update
« Reply #150 on: August 15, 2010, 03:15:23 PM »
Had to grinde the casting flashes & about 1mm off here to allow the caliper to come back far enough to get full pad contact with disc
Re: Camper Update
« Reply #151 on: August 15, 2010, 03:20:45 PM »
Well that's about it for now till I get some more machining done I think it's coming togeather pritty good Cheers Reid
Re: Camper Update
« Reply #152 on: August 15, 2010, 04:23:00 PM »
Hey Reid what did you do with the bearings on the comondoor hubs am assuming you have to machine the inner bearing out for the larger bearing .....sorta defetes the purpose of the conversion i be thinking       Cheers Neil
Re: Camper Update
« Reply #153 on: August 15, 2010, 04:31:18 PM »
Hi Neil the main inner bearing is XE Falcon fits strait in no machining the outer bearing will be machined out for bedford size same as the old castlemain kit easy as Cheers Reid
Re: Camper Update
« Reply #154 on: August 17, 2010, 03:40:36 PM »
Done a little more machining today Turned down outside diameter to fit inside disc hat & machined 3mm off the face so the spiggot came through enough for wheel to locate Next job to machine out outside bearing
Re: Camper Update
« Reply #155 on: December 21, 2010, 04:13:56 PM »
Hi guys seems its been 120 days since I last posted time flies when your haveing fun havent got a lot done but got the suspension done new bushes & belljoints all painted & back in Took a half coil off the front & it came down about 25mm & left out 1 leaf on the rear it came down about 40mm Will come down more when I get everything in like 80ltrs off water & extra batteries & all that stuff you need for camping Will put some photos up off things Ive accquired Cheers Reid
Re: Camper Update
« Reply #156 on: December 21, 2010, 04:23:55 PM »
Here is the wheels that will go on when I get the disc break's done & the disc break diff done There 16 x7 genuine Holden mags with 215 / 60R16 tyres I got from the wreckers $300 Not bad I thought & set extractors for free Cheers For now Reid  Yous all have a very merry XMAS
Re: Camper Update
« Reply #157 on: January 24, 2011, 03:46:44 PM »
Well guys im at it again the camper is up on jack stands again & the diff is out & have started to build the new one it is a VN commie disc break one that we are widening 4inches bye useing a long axel in the short side Anyway a picture is worth a 1000 words so here goes cheers Reid
Re: Camper Update
« Reply #158 on: January 24, 2011, 03:52:44 PM »
That was the old diff as you can see welded in centre 3.70 ratio 3500 RPM for 100 Ks an hour Way too many revs The new diff is 3.08 should take 1000 revs off
Re: Camper Update
« Reply #159 on: January 24, 2011, 03:56:54 PM »
Some more
