  • Dot Guests: 403
Author Topic: window removal  (Read 6998 times)
Offline Bullstik
window removal
« on: September 21, 2008, 08:40:23 PM »
is there an easy way to remove the side and back windows.
I know you pull out the rubber wedge from the outside then thats about it after that, any info would be great thanks
Re: window removal
« Reply #1 on: September 21, 2008, 08:50:43 PM »
hi, get someone on the inside and push them in,
thats the easiest way if found.
i made up a special tool to reinstall the outer rubber strip,
im still trying to find it to post pictures of the instalation procedure.
marty
Offline Bullstik
Re: window removal
« Reply #2 on: September 21, 2008, 09:00:10 PM »
thanks marty, i'll give it ago. My rubbers are abit hard hope i dont break them, maybe i should just cut the rubbers away and get new ones later.
Re: window removal
« Reply #3 on: September 22, 2008, 08:08:36 AM »
The windows are toughened or laminated, not easy to break.
Just start pushing (on the inside) from a corner, once it starts it's easy.
If it seems really stuck, as if glued in, run a screw driver around the outside rubber (steel side not glass side) this will help break the sealer/glue bond
