  • Dot Guests: 1347
Author Topic: Engine removal  (Read 14943 times)
Re: Engine removal
« Reply #10 on: July 08, 2012, 04:13:51 PM »
Removed bonnet grill rad support Had to remove the bonnet so I could get the chain as close to the center of the motor as possable & put some weight on the other end of the 3x2 to counter balance it
Re: Engine removal
« Reply #11 on: July 08, 2012, 04:17:50 PM »
Page 28 of camper updates in camper section
Re: Engine removal
« Reply #12 on: July 11, 2012, 03:26:23 AM »
does it work with v8???
Re: Engine removal
« Reply #13 on: July 11, 2012, 08:23:29 AM »
Probably have to take the manifold & heads off
Offline Worby876
    • UCB Australia
Re: Engine removal
« Reply #14 on: July 11, 2012, 09:35:28 PM »
Hi Guys....my late father Jack posted this post with pics on his oldholden shed site
On how to remove the engine 202 straight 6 from a CF Bedford
http://gallery.oldholden.com/Jack_s/MAN-ual+way+of+removing+202+Red+Motor+and+re-installing/
Check it out and see if it helps answer some of your questions. ???
Re: Engine removal
« Reply #15 on: July 12, 2012, 12:19:44 PM »
Your father, Jack is a LEGAND
Offline Stangas
Re: Engine removal
« Reply #16 on: July 16, 2012, 12:08:24 PM »
after many many hours trying to make this old 253 of mine run, i am running out of options..
it is missing on 2 cylinders i think, so i have replaced the sparkplugs and correctly gapped them, tripple checked the timing, new dizzy cap, new leads, new coil.  still missing on some cylinders.
checked the electronic ignition module and noticed that there was a chip out of one of the 8 segments (magnets i assume) so i am replacing the dizzy completely.
last thing to check is the carburettor..  is running a stangas rebuild 350 holley with 58 jets and 6.5 power valve..  all set up as per instructions.  But no matter what i do to the adjustments, cannot get away from this deadly backfire, unless i drop the fuel flow so low that it struggles badly when on the open road.
The damn thing keeps popping or backfiring in the throat of the carb...  it is leaving rings of black carbon on the driveway when i start it, so very very rich, hence me blaming the carb..
anyway...  my worst case is i have a popped a head gasket...   hence the discussion here...  if it is, the motor is coming out..  as i doubt very much you will get the head off while it is under the van.
or am i wrong, and there is a way of lifting the shell high enought to get the head off??   any assistance, otherwise i am building a frame like you guys have shown and ripping the bloody thing out...   which means full rebuild.
-BED 253-
Re: Engine removal
« Reply #17 on: July 16, 2012, 03:06:00 PM »
hey stangas i'll bet my left knacker its either a burnt inlet valve or a lobe's gone on the cam ,hence the backfiring through the carb very comon fault with ole 2 flies an aflea       do a comp test and it will tell you also check for rocker free play at tdc (shouldn't be any as they are hydraulic lash adjusted   Cheers Merlin
Offline Stangas
Re: Engine removal
« Reply #18 on: July 16, 2012, 03:17:15 PM »
i think you could be right merlin..
i have had another look and i can get the heads off...  will be a mission but do-able without taking the engine out.
i think it will come off next weekend...
cheers mate
-BED 253-
Re: Engine removal
« Reply #19 on: July 16, 2012, 05:46:04 PM »
cheers mate
Just remove the engine cover, heaps of room to remove the head then
