  • Dot Guests: 905
Author Topic: Leaf Spring Rubbers  (Read 11460 times)
Offline Marky
Leaf Spring Rubbers
« on: May 15, 2012, 08:21:51 PM »
hey all ..
the rubbers that are enclosed in the end of each of my leaf springs are shot...
need to replace them....anyone know what Model to ask for?
Is my CFL Jumbo..w holden banjo diff..10" single wheels...
maybe HQ?
Creative Media Producer
Offline VanWolf
Re: Leaf Spring Rubbers
« Reply #1 on: May 16, 2012, 07:12:28 AM »
Marky, you also need to know the spring width. I believe Bedfords came out with 2 sizes. 55mm spring width, eye diameter 28.5 mm and 80mm spring width, eye diameter 35mm width. Superpro do a urethane rear set. For the 55mm set it is about $109.00 from Supercheap.
Hope this is of help.
Mike
« Last Edit: May 16, 2012, 07:15:03 AM by VanWolf »
Offline Marky
« Reply #2 on: May 16, 2012, 08:59:15 AM »
Thanks found em here at
 http://203.31.191.243/fulcrumCat/
Offline Marky
« Reply #3 on: May 16, 2012, 09:14:52 AM »
Part No.SPF 1337K (55mm spring width...28.5 eye diameter)
$75  for a set of 12 rubbers ..6 sleeves......nice!!!
« Last Edit: May 16, 2012, 09:47:53 AM by Marky »
Offline Marky
« Reply #4 on: May 18, 2012, 05:55:38 PM »
well all is not as it seems...
got the rubber kit ....
6 sets of bushes
4 x leaf spring eye bushes
2 x rear shackle
-leaf spring eye diameter is ok..
-but my bolts are bigger in diameter..so used my old sleeves..buffed em up n are ok.. refitted them w new rubbers
-but the top rear rubbers..(shackle ones) the ones that hold the spring to the chassis rail are the wrong ones..
in the pack supplied they .way too small...
will be on the hunt tomorrow for a suitable replacement....
hmmmmmm Beddy sagas......
Offline Marky
« Reply #5 on: May 18, 2012, 08:32:32 PM »
« Last Edit: May 18, 2012, 08:42:44 PM by Marky »
« Reply #6 on: May 18, 2012, 10:51:06 PM »
ah!!, but!!!...it is......a blitish bredflord!!!....did you explect ,...any ress??..... glasshopper??  :)
« Last Edit: May 18, 2012, 10:59:18 PM by SkippyThBushKangeroo »
Offline VanWolf
« Reply #7 on: May 19, 2012, 07:24:21 AM »
Marky,
I had a similar problem with my Whiteline upper control arm bushes. They packed the wrong dia crush tubes, as you can check the specs on their web site. I rang them up and they sent new ones out. On one of the back pages on Fulcrum you can look for your bushes/tubes. Follow link.
http://www.superpro.com.au/why-superpro/find-my-bush-size
Mike
Offline Marky
« Reply #8 on: May 19, 2012, 08:51:17 AM »
well they are all wrong....this kit doesn't fit a CFL..maybe a CFS most prob..
Seeems to me CFLs had bigger everything...makes more sense w the extra weight n all
...my leaf spring eye diameter is 35mm...Spring width 55mm.........
huh?
Offline Marky
« Reply #9 on: May 21, 2012, 03:28:24 PM »
well...sent back the pack of rubbers...they are only for CFS...
no one makes a suitable replacement... ??? ???
the next size up 85mm wide..35 mm eye diameter are close..but not the right fit
so will get em turned down tomorrow arvo...after i get the new ones........
  aaaaaaarrrrggghh!!!
