  • Dot Guests: 592
Author Topic: Lowering the cf bedford  (Read 17941 times)
Re: Lowering the cf bedford
« Reply #10 on: September 06, 2008, 10:33:38 PM »
hey shaggon wagon i know exactly waht you mean!! fully awsome.. just wont sit even if its chockers!!!
full on great! yeh pretty much flat all the time..
Offline Lyndon
« Reply #11 on: September 06, 2008, 10:35:50 PM »
so removing a few leafs wont bring it down???
Lyndon
Offline stumpy1972uk1
« Reply #12 on: September 07, 2008, 07:07:17 AM »
no removing a few leafs wont bring it down , what it will do is make the rear as bouncy has hell, remember a 7 leaf spring set has been designed to work as one spring rather than 7 individual leafs.
« Reply #13 on: September 23, 2008, 08:18:51 PM »
i think you will find it will bring the back down a bit by removing a leaf.. make sure you get the right one (information sourced from the famous eddy mac!!) but if you want to go down a few inches yeh throw the diff on top and might even want to add a leaf then..
and you can use lwb springs and cut them down a bit to lower the front.. only problem is camber then.. chew out the tires a bit hey..
Offline matty
« Reply #14 on: September 24, 2008, 09:19:55 PM »
you can't throw the diff over the springs on a short wheel base as there isnt enough clearance, that is unless you
could find a longer spring that was precurved to fit, that spring would need to have the same flex rate as well as sitting much
lower. if you could find such a spring you could then use lowering blocks (which are not recommened) to get it to
sit the desired height.
good luck looking for that spring,
not 100% sure if it would work. but it sounded good in my head.
« Reply #15 on: September 25, 2008, 07:53:51 AM »
how about lwb springs??
modify mounts, use them cause the lwb diff sits on top.. then you could lower it to whatever..
« Reply #16 on: September 25, 2008, 07:56:31 AM »
orh ... bugga, I have a 9" under my campa, I took it out of a van that had the springs underslung, it was so low that when I stood at the back of the van I could see the top of the roof, this van had been registered with the suspension mods, now that I think of it there was a different leaf set up and an extension at the shackles, I know the front was wayyyyyy toooooo looooowwwww for me, couldn't get it up the driveway at the old house let alone trying to get over the speed humps where I am now, anyways, didn't fancy the super lowered van look, wasn't practicle for what I use beddies for so took the diff out and had the brackets welded back on the top, took off what I wanted and sold the van, I think it went up to a paddock in the Dandenongs, bloke wanted it as a spare for parts. That was about 4 year ago.... did like the look of the super lowered beddie though, matt black, windowless with cragars, it had a VS airdam grafted on by the previous owner (shite job) spoiled the orig lines ....... no pics sorry ...... was number 3 van in the driveway and the misuss was cracken it so I took what I wanted and moved it on ..... bugga .... shoulda ket that lowered front end !!!!
Tweaker
« Reply #17 on: October 23, 2008, 10:06:51 PM »
So how did the lowered dif end up?
Check out Joel Oswald's single leaf dif set up in his gallery. It looks great!
Add decent air bags to these and you should be able to carry some weight I would think ???
