  • Dot Guests: 1078
Author Topic: roof and gutters  (Read 14059 times)
Offline rizzo
  • 666
roof and gutters
« on: October 02, 2011, 05:34:24 PM »
Hi there i have to replace my roof  soon as the  dum ass before  me packed every square inch of the roof with sponge by the way he also put in a pop top and there is bolt holes every where so i am thinking replacing it with a roof from ben or something out of the square and welding a flat top  who knows ???? tell me what you think  rizzo out
do it today there might not be a tomorrow
Re: roof and gutters
« Reply #1 on: October 03, 2011, 05:04:14 AM »
Nooooooooooooo! Don't do it! BLECH!
« Reply #2 on: October 03, 2011, 02:58:17 PM »
go to sheet guy and get him to bend some gutter sections up and weld them in , in the last 6months there has been stacks of info on replacing the gutters including profiles and how they go together.Including a complete roof replacement.
Offline cords
« Reply #3 on: October 03, 2011, 07:31:55 PM »
this is no small job(ask me how i know) having the gutters bent up is not that easy as the gutter and cant rail is one piece and they are not straight if you can get doner gutters that is the way to go i have about 5' left in sydney as well as a roof cut with a sun roof in the front that you may be abel to get a patch pannel out of i have replaced over 10' gutter on the wifes and am about to put the roof back on it is a huge job and not for the faint hearted check out this thread if you want some idea of what your in for
http://www.buga.com.au/index.php?option=com_smf&Itemid=2&topic=2972.0
Cheers Gav
Cheers Gav
« Reply #4 on: October 03, 2011, 09:24:15 PM »
Forget the gutters alltogether and weld on some 5mm rod, it will give it a clean look but still have a "beauty line"
Offline cords
« Reply #5 on: October 04, 2011, 04:56:22 AM »
the problem with removing the gutters is the roof is wider than the sides and a lot of your strength comes from them so have a good think about it first
Cheers Gav
« Reply #6 on: October 04, 2011, 07:33:03 AM »
Save yourself a lot off trouble & heartake & money find a better one & use that one for spairs By the sounds of it there is a lot off body work & that is a pain & can be very costly Just my 2bobs worth Cheers Reid
Offline rizzo
  • 666
« Reply #7 on: October 04, 2011, 10:21:02 AM »
Hi bugas thanks for all your ideas i think i have to step back and look at the big picture and have a good think i guess iam in to much of a hurry i have to slow myself down and do things slowly rizzo out
Offline Poochimama
« Reply #8 on: October 04, 2011, 04:03:08 PM »
Hi,
My Brothers is fixing the guttering on mine now,best way as he chose is hes got about 4ft of right angle aluminum and pot rivet each end to the original roof guttering , this is his mould to do fibre glassing on inside of this guttering to get the shape.
Chipping away roof paint first OFCORSE THERE IS BLOODY RUST & BOG AGAIN in the roof,lol..so he will do patch fibre glass the holes up, sanding,then start the fibre glassing on inside of the gutter to the roof,pull away the Aluminum after the f'glass is dried then paint over new guttering. ;D
I will take pix now!
It was too bigger job for the rust in the front floors,especially driver side wheel arch was stuffed too,to cut the floor out and reweld he could but the shape &replace the wheel arch was the problem.
 ,so he fibreglassed that instead aswell and its rock hard strong will last a life time!
Good luck mark!
Offline Poochimama
« Reply #9 on: October 04, 2011, 04:16:10 PM »
Im uploading gutter/Roof pix my brothers working on now,I dont know how to upload pix here,so i put it in my Album ,go to page 7 gallery.Skull gear stick is mine!
