  • Dot Guests: 693
Author Topic: Help needed with my 1976 CF Drum brake and ball joint  (Read 5520 times)
Offline Worby876
    • UCB Australia
« on: April 03, 2011, 09:39:30 PM »
Hi Guys,
I tried to get a RWC for my 1976 Bedford Motorhome and it failed because the front drivers drum brake has a cracked drum
and also there is 5mm movement in the ball joints.
The Mechanic at MIDAS said when he rang around to get some quotes they just laughed...cant find bits here in South side of Brisbane.
Do any of you know where I can get a spare second hand Front Drum and where I can get the ball joint services or replaced etc?
This belonged to my late father and Im not as mechanically minded as he was.
Re: Help needed with my 1976 CF Drum brake and ball joint
« Reply #1 on: April 04, 2011, 08:49:26 AM »
http://www.bedfordmanor.com.au/
here you go
Rob is at Loganholme
« Reply #2 on: April 04, 2011, 11:40:47 AM »
When i was there the other day he had stacks of bits stacked up, so give him a call.
« Reply #3 on: April 04, 2011, 11:51:51 AM »
 jim withers of J W Classic Car Parts.
Good for balljoints and any mechanic can fit, all going smoothly probably about 2-2 1/2 hrs for both sides
Offline Worby876
    • UCB Australia
« Reply #4 on: April 05, 2011, 09:37:10 PM »
Thanks guys
I really appreciate the info...another great reason for being part of BUGA  8)
cheers...I will let you know how I get on.
