  • Dot Guests: 429
Author Topic: beddy gremlins at it again  (Read 17715 times)
Re: beddy gremlins at it again
« Reply #30 on: March 06, 2011, 10:37:11 AM »
Beeeeeeeeeeeeeeeeennnnnnnnnnnnnyyyyyyyyyyyyy.. whheeeeere aaaaaaaare youuuuuuuuuuu???????   how are you doin with the bearing measurments from the beddy originals .. were the measurments you have the same as a have  ???  ???  ???.. cheers dears
« Reply #31 on: March 06, 2011, 04:26:26 PM »
sorry skip been picking up beddy for mate from 6 hours away and yeh been busy ill get those measurements tommorow:)
« Reply #32 on: March 07, 2011, 08:36:49 PM »
 ;) too easy mate, when ya ready,  ;) thank you  :-*:-* as in "just in a hey way, not in a gay way" )
« Reply #33 on: March 10, 2011, 10:09:23 AM »
sorry it took so long.
i had a look at a few 10inch drum bedford axels the same as yours as far as we can tell.
bearing same for both axels i have here
width - 27mm
outer dia 80mm
inner dia 34.85mm
collar width
1st axel 14.75
2nd axel 11.75 -
the orig collar is no longer avail apparently so this one is commonly used now.
hope this helps.
« Reply #34 on: March 10, 2011, 10:11:44 AM »
Been chatting with a bloke who has got people to do research on a replacement rear axel bearing at reasonable price.
its 3mm narrower than the bedford orig bearing.
came up with
Transmission bearing no.
TMSC0788NRCS40
dimentions
80mm outside (same)
35mm inside (same)
24mm width (orig 27mm)
this bearing is so far untrialed untested..
on the phone now to bearing people.ost up any more info i get.
some problems have arisin.. bloke getting back to me..
here is something else i reaserched a while ago may be helpful??
« Reply #35 on: March 10, 2011, 10:52:05 AM »
thanks mate  ;) will recheck my bearings again  ???
