  • Dot Guests: 394
Author Topic: gutters  (Read 24511 times)
Offline jetman
  • probationary
gutters
« on: August 23, 2010, 11:17:02 PM »
hey everyone finally am able to start my resto got a fair bit of rust on the gutter and roof and been chatting to a few people and they reckon I should grind the gutters off and mig them I'm not so sure. any advice would be welcome also does anyone know of a panel beater who doesnt run to the hills when you mention bedford vans
Re: gutters
« Reply #1 on: August 24, 2010, 06:42:33 AM »
This will change the look of your van.
Some people love the look, but others hate it.
But there is no doubt that gutters are a pain  when it comes to holding water.
Mine are quite bad in places, and I'm wondering about deleting them and welding the roof on too.  :-\
Offline waikatostocky
Re: gutters
« Reply #2 on: August 24, 2010, 07:40:40 AM »
i quit like the look of them have had the whole front of the roof cut out and replaced and have had the gutter replaced.
cheers Paddy
be safe out there
Re: gutters
« Reply #3 on: August 24, 2010, 08:32:26 AM »
It's a very big job. The roof actually overlaps the side of the van so that has to be shrunk back and I think you are also dealing with three different edges. The roof, the gutter which extends inside the van and the side of the van itself.
Re: gutters
« Reply #4 on: August 24, 2010, 08:35:11 AM »
My gutters were shot when i got the van, i have taken some of my gutters off, but when i redo the body this time round, i am going to look at ways of loosing the water better then the original set up. But the roof is a while off, i need to get the rest of the body mods done first, and i will need to run some ideas past my sheet metal guy as we go. This probably does not help you now, but i will be reducing the amount of gutters i have, i guess, look at where the water is standing the most and loose that section.
Re: gutters
« Reply #5 on: August 24, 2010, 09:08:38 AM »
The one on the back of my van was removed when the bobtail and new rear panel was fitted and I also had the one on top of the windscreen removed and had it redirected down the sides of the windscreen. Best thing I ever had done and stops water being blown through the front door seam when you're driving if your door seals aren't all that watertight.
Offline Mark B
  • '79 CF SWB
    • Some of My Music
Re: gutters
« Reply #6 on: August 24, 2010, 09:38:57 AM »
Hey Rouge, do u have any picture of this?
http://abakersdozen.com.au
Re: gutters
« Reply #7 on: August 24, 2010, 10:39:40 AM »
This is about the best I can do here at work. I can take some when I get home tonight if you want a bit more detail.
Offline Mark B
  • '79 CF SWB
    • Some of My Music
Re: gutters
« Reply #8 on: August 24, 2010, 10:49:18 AM »
Thanks mate!
I see what you mean about the redirection.
Re: gutters
« Reply #9 on: August 24, 2010, 10:57:30 AM »
i had often thought of leaving the front gutter on but , snipping the gutter across the upper windscreen qtr and continuing it down the ledge and doing the same at the rear. about 50mm so you get run off front and rear.
