  • Dot Guests: 1100
Author Topic: spot the difference!  (Read 15713 times)
Offline grandad
Re: spot the difference!
« Reply #10 on: August 11, 2010, 04:45:05 PM »
add says deceased estate. wish someone would leave me a beddy in they will
Offline jesus_is_alright
« Reply #11 on: August 11, 2010, 05:59:18 PM »
Hey guys, thats my new beddie, and yes i did notice the backwards-ness, was gonna ask you guys about it
the plus side is i can open the passenger door whilst the side door is open
the down side is i cannot get it to lock properly. I lock it in the morning, and when i get to work its unlocked..?
Hasn't opened by itself yet though.
Oh and if you look really close, the door handle is the same, just upside-down (and not in line with the passenger door)
I asked the seller and he swears it was like that from factory (perhaps a custom option)
I am seriously considering re-hanging it the "normal" way
-Aaron
« Reply #12 on: August 11, 2010, 06:38:35 PM »
the lock would riggle loose (unlocked) - gravity.
To fix it, turn the handle around and have it above the lock mech.
the upside down door handle shows its not factory.
Offline grandad
« Reply #13 on: August 11, 2010, 06:44:23 PM »
have you still got your old van shouldnt be that hard to take the door off that van and swap it over
« Reply #14 on: August 11, 2010, 09:28:35 PM »
theres a reason there called suicide doors......
« Reply #15 on: August 11, 2010, 10:09:38 PM »
mmmmm, door unlocking it self...... deceased sale.... spooky  ;D
if this pack of beddyfiles have never seen a reverse side door then i doubt its factory.
« Reply #16 on: August 11, 2010, 10:11:33 PM »
TURN IT INTO A GULWING DOOR, THEN IT OPENS UP. ;D the door must be confused on what is the correct way to open, at least they got the door the right way up when they changed it..................
« Last Edit: August 11, 2010, 10:14:27 PM by Bas NZ »
« Reply #17 on: August 12, 2010, 08:27:35 AM »
If i was you i would take this chance to remove all your beddy handles and fit commodore handles, its a simple job. That way you will be the only van NOW that has a reverse door, and handles that you can get parts for over the counter, have a look at my van in my gallery, mine work as smoothe as if they were factory fitted.  If your door does not leak, and it sits in it's opening correct i would leave it as is.
« Reply #18 on: August 12, 2010, 10:27:48 AM »
I've seen a couple like that in the past - not sure if its factory or not.
Offline atk1
« Reply #19 on: August 12, 2010, 03:35:04 PM »
Ive got 2 side rear suicide doors on my van/ute. I use a drivers door handle and catch etc for the passenger side suicide door and vice versa
« Last Edit: August 12, 2010, 04:23:32 PM by atk1 »
