  • Dot Guests: 417
Author Topic: window regulator  (Read 7167 times)
Offline beddymad
  • new project
window regulator
« on: August 03, 2010, 05:57:17 PM »
hey guys just a quick question,i need to replace the plastic wheels that run in the window channel of the window regulator.are they still available or is someone machining them?any info welcome cheers
Re: window regulator
« Reply #1 on: August 03, 2010, 06:24:59 PM »
i went to the local bearing shop and said want something to replace this!
$5 later I was a happy man
will try to find a number 2morro
« Reply #2 on: August 03, 2010, 07:50:51 PM »
yeah that'll be good hotrod....cheers
Offline Dave
« Reply #3 on: August 03, 2010, 09:56:02 PM »
there are a couple of threads on this
try searching on this one it mentions part numbers "Re: Window Winder Troubles?!? "
somewhere I also put on a string showing a part number for a bearing from an aluminium door that I was put onto by a friend who was an aluminium door salesman, it is a good fit, is available from Bunnings, is real cheap and has worked fine for a year or two
possibly the old forrum
regards
dave
« Reply #4 on: August 04, 2010, 11:16:39 AM »
There is a window rubber place over here in Croyden, Antique rubber or something, they had them years back, they do all swap meets... any one know there name
« Reply #5 on: August 04, 2010, 12:02:55 PM »
go to a house Alluminium slideing door place and get the little wheels that the slideing flyscreen doors run on up the top,
ive done it a few times, they fit perfect have ball bearings  and are cheap as.
just grind the stud off the orig one and use a stainless steel bolt and nyloc nut to refit the flyscreen roller
« Last Edit: August 04, 2010, 12:05:13 PM by mty »
« Reply #6 on: August 04, 2010, 12:09:22 PM »
The roller bearings would be better rhan the factory ones
Offline beddymad
  • new project
« Reply #7 on: August 04, 2010, 06:32:01 PM »
thanks guys ill check bunnings out tomorrow.cheers :)
