  • Dot Guests: 1469
Author Topic: Auto to Manual??  (Read 10557 times)
Offline N.Berenyi
Auto to Manual??
« on: July 10, 2010, 07:26:49 PM »
Hi guys,
I've been looking at buying a van for ages now and I think I might have found one!
The only problem is I only have my auto licence and the van is a manual.
Does anyone know the average cost of changing a 202 manual to auto?
I've been trying to get in contact with JB Auto in Dandenong, Victoria for a quote but can't get in contact with him (Joe).
The van itself is well within my budget just need to know if I can afford it all.
Any help? or contacts in Victoria?
Nick  :)
Re: Auto to Manual??
« Reply #1 on: July 10, 2010, 08:09:29 PM »
hey mate, it's very easy to do
call any early model holden wreckers and you'll find the parts you need at a good price.
The only thing im not 100% sure on is if the tailshaft lengths are the same between holden H series and a bedford, but if not it's very easy and reasonably cheap to get a tailshaft modified.
« Reply #2 on: July 10, 2010, 09:01:26 PM »
it'll b a shite load easier gettin ya manual licence, and chaeper, good luck! ;)
Offline N.Berenyi
« Reply #3 on: July 10, 2010, 09:12:22 PM »
I knew someone would say that  :)
After my P's I can drive manual anyway but I still prefer Auto. I can drive manual but I like Auto simple as that.
Thanks for the help so far.
delrazor
« Reply #4 on: July 11, 2010, 01:15:26 PM »
Hey Nick,
i am going through the same thing.
Look for a thread called "installing a trimatic - step by step" I'll post the processes and costs as i go.
I'll get on now and update it.
derek
http://www.buga.com.au/index.php?option=com_smf&Itemid=2&topic=2112.0
« Reply #5 on: July 11, 2010, 07:50:42 PM »
Nick, go for it, easy swap, now the other way around is a lot more trouble. Need to remove the bearing in the back of the gear ring (heat it up)  and replace with a auto bush. lose a pedal, and driveshaft modifiy, kick down set up on carb, crossmember not sure but will be easy to make fit, trans oil cooler or swap to auto raidiator.
« Reply #6 on: July 11, 2010, 07:59:36 PM »
should not have to change drive shaft..
« Reply #7 on: July 12, 2010, 05:17:51 PM »
I think ben, the drive shaft needs to be shorter.
« Reply #8 on: July 12, 2010, 05:49:43 PM »
hey Bas, i made the same mistake, but fortunately my comments were relevant to both conversions.. he wants to do a manual to auto conversion - not an auto to manual conversion..
but anyway, bas if you were talking about heating up the spigot bearing to get it out, there is an easier way.. get a bolt a bit bigger than the size of the spigot shaft and grind the end down a bit so you can screw it in, then you can just pull/wiggle it out..
« Reply #9 on: July 12, 2010, 09:26:42 PM »
all the ones iv done 4 iv never had to change the length
