  • Dot Guests: 1003
Author Topic: a few more questions for you guys  (Read 9883 times)
bradford
« on: May 26, 2010, 08:56:29 AM »
new tie rod ends are in but hoping to locate tail light assemblys, indicator stork assembly ( or does anyone know if another stalk fits) and also a steering column cover, thanks guys
Offline Mark B
  • '79 CF SWB
    • Some of My Music
Re: a few more questions for you guys
« Reply #1 on: May 26, 2010, 09:23:31 AM »
Hey Bradford,
I have read on here that a indicator stalk for a mini will fit - some same wiring harness, some different but same plug..they just need re-wiring if not and are the same colors as beddy  ;D
Call Ben for the rest of the stuff if your don't hear from anyone else  ;D
Cheers!
http://abakersdozen.com.au
danvanman
« Reply #2 on: May 29, 2010, 12:28:02 PM »
Land rover indicator stems are same too.. I think my last one was $25..  you may need to put the wire plug/joiners on tho?
Offline Worzel
« Reply #3 on: May 29, 2010, 08:45:39 PM »
series three landy
bradford
« Reply #4 on: June 04, 2010, 07:16:48 PM »
thanks 4 the info guys but no landrovers to be found in adelaide so far ill let u know how i go
« Reply #5 on: June 05, 2010, 08:36:31 AM »
hey bradford, i would try a dealership, they may be a bit more pricy, but at least you will get a new one that will last for years.
Offline Rothu
« Reply #7 on: June 05, 2010, 02:57:19 PM »
I used an old (70s) falcon stalk assy. I just rewired it and it works brilliantly.
bradford
« Reply #8 on: June 07, 2010, 03:47:15 PM »
thanks again chaps. i ended up going with worzel's ebay link for the rover stalk. cheers worzel. also mark b said to giv ben a call for some parts. anyone got ben's number.
Offline Rothu
« Reply #9 on: June 10, 2010, 11:15:28 AM »
I was down at the wreckers yesterday and they have 4 4 drawer filing cabinets full of steering column indicator/lights/wiper assys.
The Bedford column is 320mm in diameter. so I measured a whole bunch because I'm going to have wipers and lights at my hands on the column rather than those stupid bloody switches!
As long as you can follow the simple wiring it's pretty easy to reroute the switches.
What I found is that early model Nissans all had bolt on assys, most of them at 320mm. solid buggers too! Unless you plan to move the bearing at the top of the column, it's far easier to get bolt on ones. But I settled on a Toyota (unmarked) for it's ruggedness, and it fits nice and snugly within the bedford column cover with only another hole made for the left wiper stalk. I'm taking lots of photos and electric logic wiring diagrams. Will post photos of the the changeover soon.
