  • Dot Guests: 1450
Author Topic: need advice on dent  (Read 17736 times)
Offline Lyndon
need advice on dent
« on: August 16, 2008, 05:58:23 PM »
need helpfull advice on the dent i got when a sign was reversed into last night, do i cut n shut or tapp out n fill? id like to get a section to replace it but where?
Lyndon
Offline Jock
Re: need advice on dent
« Reply #1 on: August 16, 2008, 06:46:17 PM »
How did it happen??? That's a real shame Lyndon... are you gutted?
I accidently clipped a concrete wall the other day and it scuffed my rear guard - I was gutted.
Hope you can beat it out without too much trouble.
Offline Lyndon
« Reply #2 on: August 16, 2008, 06:49:00 PM »
thanks Jock, reversed into a sign & yes im gutted to see it, been peed off for a while & need to fix it asap.
Lyndon
« Reply #3 on: August 16, 2008, 11:26:14 PM »
common its just a love scratch..
Offline Jock
« Reply #4 on: August 17, 2008, 01:56:53 AM »
you should be able to beat it out and then re-spray that section without too much effort.
Do you have a mate that works as a panel beater / paint shop?
Where abouts are you?
Jd
Offline Lyndon
« Reply #5 on: August 17, 2008, 01:57:53 AM »
port pirie sa
Lyndon
Bren
« Reply #6 on: August 18, 2008, 11:58:22 AM »
definitely don't cut it out. you would just make more problems for yourself.
should only take an afternoon to get back in to shape.
Offline Lyndon
« Reply #7 on: August 18, 2008, 01:47:59 PM »
thanks Bren & others for your advice, ill knock it out from the onside & then fill it with top quality light weight filler in minumal amounts as possible.
Lyndon
« Reply #8 on: August 18, 2008, 06:02:48 PM »
one of the reasons i drive a beddie cause its real steel, just imagine if that was a high priced Tarago or similar, you coulda cut it out with a can opener and glued a bit of plastic over it  :D
« Reply #9 on: August 18, 2008, 07:21:06 PM »
damn straight!!
