  • Dot Guests: 374
Author Topic: seeking the right power steering unit for my bedford  (Read 35558 times)
Offline Jock
Re: seeking the right power steering unit for my bedford
« Reply #10 on: August 19, 2008, 06:51:31 PM »
A good price to pay for power steering hunter.... What other parts are you going to use for
the conversion? What pump etc. Well done so far. Jd
Offline hunterbynature
« Reply #11 on: August 20, 2008, 04:34:34 PM »
hi jock i have a hilux power steer pump i have been adapting, they are small and easy to get, all the gm pumps seem to leak eventually due to the pressed steel housing and are a lot larger than the hilux pumps, the only thing is you have to run a seperate resevoir wich is good if your pressed for room and you can mount it for easy access, i have talked to the power steer guys and they seem to think the hilux pump will be ok, a road test will soon sort that out anyways cheers stevo 8)
The Cheeky Kiwi
Offline Jock
« Reply #12 on: August 20, 2008, 04:52:47 PM »
Some pics of fitting the hilux pump would be good, where are you going to mount it?
Jd
« Reply #13 on: August 20, 2008, 06:38:26 PM »
hopefully gonna mount it on the right hand side between motor and steering shaft, have power steer rack mounted and motor in so gotta sqeeze it there somewere, will take some pics in the weekend and post them for you cheers stevo 8)
The Cheeky Kiwi
Offline Lyndon
« Reply #14 on: August 21, 2008, 03:08:12 PM »
Rogue whats the part number of the rack? i have the porsche wreckers in the usa asking.
Lyndon
Offline Lyndon
« Reply #15 on: August 21, 2008, 06:53:05 PM »
Hunter where can i get the same from?
Lyndon
« Reply #16 on: August 22, 2008, 12:58:14 AM »
Doeas the Porche power steering rack fade at greater speed????, so it's not so sensative at say 140kph ?
Tweaker
« Reply #17 on: August 22, 2008, 07:57:16 AM »
I think you'll find that's the pump.  ;)
I've got a 1976 XC Fairmont. It's no problem down the when screaming down the highway and is easier and liter than a new Commodore when parking ;D and it's all original.
« Reply #18 on: August 22, 2008, 12:52:08 PM »
hi lyndon got mine of a private sale on ebay but german auto dismantlers in the us have them, i bought a 944 rack and that cost me about 320 bucks , will find address for you cheers stevo
The Cheeky Kiwi
« Reply #19 on: August 23, 2008, 03:28:12 PM »
hey lyndon www.germanautodismantlers.com  i have dealt with these guys before for some parts but make sure you tell them exactly wat you want and maybe send them a pic, they are yanks and good to deal with but hardwork somtimes, must be our accent or something, any way give them a call, im sure they will have one there cheers stevo 8)  oh and make sue you get the steering coupling aswell, could save you abit of frustration if you try and get one thats not matched to the rack.
The Cheeky Kiwi
