  • Dot Guests: 639
Author Topic: borg warner conversion price  (Read 32419 times)
Re: borg warner conversion price
« Reply #20 on: March 22, 2010, 05:12:46 PM »
Booked for 150km, speedo showing from what I can recall was 155km, fully worked 202 Red, trimatic with overdrive, cresta 3.5 rear end. The overdrive being the main reason it can pull 150km no probs, only a little shaking in the van.
« Last Edit: March 22, 2010, 05:14:29 PM by Bas NZ »
Offline JOE RYAN
« Reply #21 on: March 22, 2010, 10:07:11 PM »
Hey Bas NZ
Are those overdrives hard to get in NZ I have had no luck trying to chase one down in AUS, any contact phone numbers please
Joe
« Reply #22 on: March 23, 2010, 12:38:13 AM »
far out, we only alloud 2 do 110kms/ph over here.
im stickin to 80 to 100kms its safer, lol,
plus betty the beddy will like it 2, :D
« Reply #23 on: March 23, 2010, 06:15:09 AM »
Hey Bas,  I'm after one too - overdrive unit that is, and 3.5 gears .....
Offline Mark B
  • '79 CF SWB
    • Some of My Music
« Reply #24 on: March 23, 2010, 08:58:00 AM »
count me in too - if any available or group buy etc.
overdrive and gears - please
http://abakersdozen.com.au
« Reply #25 on: March 23, 2010, 12:48:41 PM »
i would be intersted in one too depending on cost
Offline Worzel
« Reply #26 on: March 23, 2010, 05:01:52 PM »
me too :)
« Reply #27 on: March 23, 2010, 05:43:26 PM »
I'm not.  :P
« Reply #28 on: March 23, 2010, 07:09:47 PM »
be handy for fuel economy, cruise on less revs thus less fuel consumption.
Offline Rocket
« Reply #29 on: March 23, 2010, 08:24:58 PM »
I found that an overdrive improved fuel economy marginally depending on diff ratio in the first place. I had a 2.75 ratio 9" added an overdrive then changed diff to 3.5 & ended up with the same economy ( overdrive gave me 5% improvement only over no overdrive). The biggest factor is the frontal area & weight of the van. Swapping the holden six for a 350 chev only dropped my consumption by 6% but I put this down to all the drive train & motor adding 250kg to the weight of my van.The biggest advantage of an overdrive is lower engine revs & makes it a lot quieter & prolongs the life of the motor.
