  • Dot Guests: 893
Author Topic: borg warner conversion price  (Read 32195 times)
Re: borg warner conversion price
« Reply #10 on: March 20, 2010, 08:09:23 PM »
cool thanks Marty will look for it.
« Reply #11 on: March 20, 2010, 08:48:48 PM »
here,s 2 pictures, showing the adjustment from 1 extream to the other ,
its kinda like the adjustment on an old clock,
« Reply #12 on: March 21, 2010, 05:48:30 AM »
Isn't that adjustment more for altering the set point of the speedo? If you want your speedo to read accurately you are going to to have to alter the gearing on the end of the speedo cable where it fits into the gearbox. There are also some outfits that can make you a little geared box that you can fit between the gearbox and the speedometer that will change the ratio so it will read correctly.
This outfit should be able to help. Don't know of any locally.
http://www.robinsoninstruments.co.nz/
« Last Edit: March 21, 2010, 05:55:13 AM by Rogue Trooper »
« Reply #13 on: March 21, 2010, 12:41:07 PM »
Rogue is right , u will need 2 change the gearbox cog to the right colour one, the adjustment is just 2 fine tune the speedo.
« Reply #14 on: March 21, 2010, 01:51:25 PM »
just did a test with my cordless and a speedo cable,
far out there is 50kms/ph of adjustment there. witch makes sence as the adjuster turns about a quarter of the circumference of the speedo gauge.  :)
i would have thought there might be 20kms/ph max  but blew me away that there was 50kms/hr
 be a lot easier changeing the cog as the whole dash needs pulling apart 2 get 2 the adjuster,
(bloody bedford designers) what were they thinking when they did that? ???
« Last Edit: March 21, 2010, 05:39:13 PM by marty »
« Reply #15 on: March 21, 2010, 06:30:40 PM »
LS120, if you are running the 3 speed Trimatic, you change the cog in the auto where the speedo cable fits, to a white one, if I remember right, I did this and I know it's ok because before I took it of the road I was clocked at a 150km on the open road and issured a ticked for this speed I tried to tell the cop that a bedford could not reach this kind of speed, but for some reason he still gave me the ticket......... >:(
« Reply #16 on: March 21, 2010, 08:30:48 PM »
far out, ive had my beddy SWB 202red 4 speed aussie, borgwarner diff up 2 130kms an hour but she wasnt likeing it 1 bit so i stick 2 110kms
u got a V8 Baz? n what was ur speedo showing when he booked u for 150?
p.s. i stick 2 the speed limits if its 60 i do 60, 80 i do 80, 110 i do 110 was just testing her out when i reached 130
« Last Edit: March 21, 2010, 08:33:29 PM by marty »
« Reply #17 on: March 21, 2010, 09:36:29 PM »
ledgend marty!!
« Reply #18 on: March 21, 2010, 09:43:41 PM »
 :o! I been hyjacked!!  lol
« Reply #19 on: March 21, 2010, 10:05:13 PM »
haha, good on ya ben, hope ur gettin better, ur banned from spinning things,  ;D 2. lol
hey craig its better than being jackedhigh,  :D
