  • Dot Guests: 1750
Author Topic: bubble windows  (Read 28638 times)
Offline jimsvan
Re: bubble windows
« Reply #10 on: February 07, 2010, 10:24:22 PM »
hi everyone i have a lwb bedford van and im trying to hunt down a bubble window for the back of my van can anyone help me im in melb australia
Offline Mark B
  • '79 CF SWB
    • Some of My Music
Re: bubble windows
« Reply #11 on: February 09, 2010, 11:24:22 AM »
Hiya Jim,
Send a PM to Arron, a few posts up.
He does awesome bubbles and quick turnaround, great communication.
You can see them in my gallery!
http://abakersdozen.com.au
DiscoBeddy
Re: bubble windows
« Reply #12 on: June 19, 2010, 04:19:56 AM »
Hi guys,
I've had Aaron's famous bubble windows for ages but every time I've attempted to find some time to have them installed properly, I have kinda hit a dead end with regard to finding someone who is willing and confident to install them...  A couple of panel shops just have not wanted to know me, and one place said "if you didn't get any rubbers with the windows, it just can't be done"!! Turkeys.. Anyway, does anyone have somewhere/someone they can point me to, who can cut 2 x round portholes (1 x each side)  and install those as well as my 2 bubble replacements for the standard back door windows?  I am in Melbourne. (Thornbury)
Wifey paid for the bubble windows, the Christmas before last (!) - (I have really dragged the chain on this!!) but it's finally time and I'd like to get it done properly..  Also, any ball park ideas on what
installation should cost me?
Your sagely advice would be warmly welcomed :-)
Cheres
Brett
Re: bubble windows
« Reply #13 on: June 19, 2010, 08:31:48 AM »
there is a place on Cheltenham road in dandenong that sells plastics and also bubble windows, they dont custom make windows but sell standard panel van ones, i am sure they do installation also. I dont have a name (sorry) but they are almost opposite the hammond road / cheltenham road t intersection.
Re: bubble windows
« Reply #14 on: June 19, 2010, 02:14:02 PM »
hey disco beddie shouldn't be that hard as you know ,I reckon 4-5 hrs max, at what ever rate. side windows mark and prep 40min, cut 30mins fit both rubbers n windows n seals +clean up 1hr. rear windows remove old windows n seals 30 min, replace rubbers windows  and clean up 1hr . 1hr just cause you know it don't always go as planned,
the look on the service mans face when you mention Bedford.........Priceless ;D
Re: bubble windows
« Reply #15 on: June 19, 2010, 05:11:37 PM »
hey disco, any half baked sheet metal guy should be abl to help you. As for the rubbers, i would of thought a H rubber would solve the problem, should not take more then an hr once sides are marked out.
delrazor
Re: bubble windows
« Reply #16 on: June 19, 2010, 05:25:15 PM »
Hey disco, bring it around and I'll set to it with the  9 inch.
when I'm done mine will be thre prettier van.
good to see the discoteque back on the rd. Did you hear my new horn the other arvo (at K).
dekmo
Re: bubble windows
« Reply #17 on: June 19, 2010, 09:52:46 PM »
hey mate, i put all my windows in with no previous experience, it's not overly hard.
You'll obviously have to cut the holes first, what you'll want to do is measure out exactly where you want them, measure twice-cut once. you can pretty much trace around the windows when you've got the spot worked out right, but you'll need the hole a few mm bigger than the edge of the window, 3-4mm should be fine, but it has to be the thickness of the rubber, the more space the better.
As for putting the windows in, kero is the key. put the rubber in a tray of kero, brush some kero on the body of the van, put the rubber onto the body, then put kero on the window and start working it into the rubber. You really want 2 people, one inside the van and one outside.. i put 4 windows in fine, but the 5th was a bit tight, so when i jumped inside to push it back flush, the window popped out and cracked (Not happy). You'll find it gets more difficult as you go, so keep applying the kero to keep things fluent.
We folded a screwdriver and ground it to a blunt point, but a really small flat blade was just as good if not better. The kero will make a big mess of the body, but dip a rag in the kero and wipe over the body and she'll be good as new.
I bought the rubbers from woodsies, i think i needed 9m and it cost about $100. anyone that stocks spectrum rubbers should be able to obtain them tho.
Re: bubble windows
« Reply #18 on: June 20, 2010, 12:52:18 AM »
ok listen up to the ole timer ere and ill show ya how its done (the easy way) first size and cut ya holes second stick some paint around the bare metal (saves the rust heartache later!!) now the magic bit fit the seal to the glass then grab some nylon rope (about 4-5 mm thick) fit that into the outer groove of the seal all the way around starting in the middle at tha bottom then sit the window in the openning with the bottom edge and one corner in thr groove apply light pressure to the outside of the glass and slowly work the rope out pushing the window into place as you go (going opposite to the corner already inserted ) this method is usually much easier to do with two people   cheers Neil
Re: bubble windows
« Reply #19 on: June 20, 2010, 10:16:40 AM »
i remember helpin my brother put the windscreen in his S series valiant, when we lived in sydney years ago with exactly th same  method as u descibed merlin , yep had it fitted in bout 10 minutes piece of the proverbial, cleaned the excess silicon off an with a reco,d motor we headed off round aussie to right up the top then down the guts, stopped in the alice for a month . . .lol. . left 3 years later in 88. . . . sigh  th good old days  ;)
