  • Dot Guests: 898
Author Topic: diff.....icult!  (Read 23459 times)
Offline Worzel
Re: diff.....icult!
« Reply #10 on: December 02, 2009, 01:57:18 PM »
if that bearing is orig you can still get them but skf dont make them any more, but another mob do, usually about $250 each thou. expensive.
but first check out
http://www.buga.com.au/index.php?option=com_smf&Itemid=2&topic=1169.0
I just used my last spare wheel bearing and picked up another on ebay uk for $30 delivered ($10 for the bearing).
They're out there all the time, but if you don't want to gamble on it actually being the right bearing if/when it turns up then jeff is the go.
Re: diff.....icult!
« Reply #11 on: December 02, 2009, 07:34:45 PM »
hey skippy you got a 9 inch modifyed for bedford.. axels which have standard bedford wheel bearings on them. expensive!!!!! make sure the axel is alright where the bearing goes on the one that the bearing busted if the bearing has been spinning around on the axel it will have worn down the axel and you need to throw it away.
Re: diff.....icult!
« Reply #12 on: December 02, 2009, 07:54:57 PM »
hey skippy that looks like a chev in the baby. what ya got?
Re: diff.....icult!
« Reply #13 on: December 02, 2009, 09:28:01 PM »
yes woz..am hopin it isnt too worn.. if not woz hopin to maybe use a punch around that area so,s it will grip..maybe locktight as well will have to see if too much meat gone wen get vern on it tomoz.. let u know.. its a holden 253 ben..whoever did it dudnt do too bad a job ..just had to adjust the radiator to fit betterer an move trans cooler up to front...wiring is a bit of a horror lots of wires goin nowhere,..is dedicated to gas too.. has 3 tanks in it should be able to get to melbs wivout fillin
Re: diff.....icult!
« Reply #14 on: December 03, 2009, 01:29:11 AM »
does anyone have the bearing number for the standard bedford wheel bearing  thanks
Re: diff.....icult!
« Reply #15 on: December 03, 2009, 01:38:35 AM »
hey Skip, don't stres cous, I run two of these diffs ,( I think they're the best for beddies) check my gallery it has all the measure ments you'll need , part # 's too, but (just skimming over the posts) how do you know there beddie axles, try bronco bearing numbers , but mainly take the bearing and collar into a bearing supplier CBC for eg, they'll get the vernia's out and should be able to match them,mine were $130 inc collars $50 to press off/on  I'll confirm my #'s tomorrow
Re: diff.....icult!
« Reply #16 on: December 03, 2009, 11:49:56 AM »
thanks dano onya.. spent hours searchin bearing sites last night, till i could bear it no more :D even cut into me BF2 time online which is sacreligious.... skip
Re: diff.....icult!
« Reply #17 on: December 03, 2009, 11:52:35 AM »
re the axles posted some pics in gallery...ben checked em out seemed to think that wot they were .. also coincides with spline numbers as swb run 21 or 27 these are 21  cheers dears
Re: diff.....icult!
« Reply #18 on: December 03, 2009, 12:03:50 PM »
soz.. just reread bens comment.. his actual comment woz  9 inch diff modifyed to bedford axles so guess theyre fords as casings are....  modifyed with the different holden stud pattern?? did you get the feeling they may be bronco axles?? would like to know its whole ID before buying...puttin a clutch in me mitsi 4WD one time .. it woz bout 60 km from shop to mitsi they gave me the wrong clutch ass 3 times. woz hoppin mad (excuse the pun ;D) by end of it.is there a minimum dia for the taper at the bearing end of the axles ??
Re: diff.....icult!
« Reply #19 on: December 03, 2009, 02:31:31 PM »
nah just lok to see if were the bearing sits has created a lip. if it has its shot unfortunatly, i have spare axels if you need one. of course youll need to get it redrilled thou.
