  • Dot Guests: 672
Author Topic: front end rebuild  (Read 11794 times)
front end rebuild
« on: September 28, 2009, 04:22:03 PM »
ok i'm going to put a 202 & 4speed into the camper & have to do the suspension arm upper's & lowers, suspension arm bush's, Front axle mount insulators & controll rod insulators.
the prices i've got so far in NZ $
suspension arm ball joints (upper & lower) $40 + gst each
suspension arm bush's upper $400 + gst (both sides)
suspension arm bush's lower $400 + gst (both sides)
front axle mount insulators (no can get)
control rod insulators $ 150 + gst (both sides)
any one have any better prices??
Offline Marky
Re: front end rebuild
« Reply #1 on: September 28, 2009, 04:41:28 PM »
Suspension arm Bushes (Control Arm Bushes) $150 uppers @ Pedders suspension Aust.
Steering arm bushes too.
Creative Media Producer
« Reply #2 on: September 28, 2009, 04:42:03 PM »
whilst were at it I received this email reply last night.
Craig
  Thank you for your enquiry on the Bedford Van. We currently have the upper and lower control arm bushes on the shelf. The price for both kits is a total of $161.oo.
We do not list a swaybar for this vehicle but with some measurements i’m sure i could have the bar bent up for you. Unfortunately I do not have a price for that until I have the required measurements and spoke to the swaybar manufacturer.
  If you have anymore questions please do not hesitate to contact me.
Duncan MacDonald
Store Manager
56 Collingwood Street, Osborne Park WA Australia 6017
Tel: +618 9244 9544 Fax: +618 9244 8855
« Reply #3 on: September 28, 2009, 07:06:28 PM »
hi Craig what would the P&P to nz be??? could you find out for me or there web site to order from...
Thanks
David
« Reply #4 on: September 28, 2009, 07:07:56 PM »
also found this site & ordered a 1 pint tin to do the front beam & control arms in..
will keep ya posted.
« Reply #5 on: September 28, 2009, 07:10:07 PM »
man i'm good every boady knows whom i'm talking about.... ;D ;D
but just in case here it is for the rest of you;
http://www.rustbullet.co.nz/epages/rustbullet.sf
« Reply #6 on: September 28, 2009, 09:12:38 PM »
« Reply #7 on: September 29, 2009, 10:40:34 AM »
Well after following the link and reading the blurb I do :D
Sounds a bit like the POR15, is it any good ? is it made in NZ, can we get here in OZ ?
« Reply #8 on: September 29, 2009, 05:37:53 PM »
yea it sounds like por15 & i've used it but por15 has limitations and this doesnt seam to have the same..
on the front end rebuild...
from pedders;
pbj148 x 2 = 99.00 + gst (chassis part)
pbj24 x 2 = 89.00 + gst (chassis part)
ep6114 x 1 = 116.00 + gst (urethane control-arm bush)
ep6115 x 1 = 125.00 + gst (urethane control-arm bush)
hmmmm
whats missing...
« Reply #9 on: September 29, 2009, 05:39:28 PM »
hi warren.. if you go to the locate a retailer by me it shows them in AU as well as all over the world.
