  • Dot Guests: 873
Author Topic: Reco'ed 186 for gas wanted.  (Read 10433 times)
Offline Rothu
« on: August 06, 2009, 11:27:01 AM »
G'day all!
My Knightmare has a slow leaking head gasket and a host of other problems so I'm looking to replace the engine totally!
Anyone got a spare 186 that has been reco'ed for gas (ie: hardened valve seats) for a decent price?
Also looking for the proper diagrams for machining holden disk rotors to bedford bearings.
Any help would be great.
« Last Edit: August 06, 2009, 11:51:58 AM by Rothu »
Re: Reco'ed 186 for gas wanted.
« Reply #1 on: August 06, 2009, 12:01:17 PM »
That's in the 'Technical Documentation' section!
« Reply #2 on: August 06, 2009, 05:28:16 PM »
Dont know if you'd be interested but i will have a 173 fitted on gas coming out shortly, the donk runs really strong with no smoke. When i rip it out for the v6 transplant its all up for grabs and it'll be free t anyone on this site.
let me know if your up for it.
Mezzmo
« Reply #3 on: August 06, 2009, 08:57:21 PM »
wow, that sounds like a motor for Warren's camper  ;D, give us a bell when its out and we'll pick it up (and check out your flash van while were at it) Eddy
« Reply #4 on: August 06, 2009, 09:34:42 PM »
Yeah better than that buga thats in there now :)
« Reply #5 on: August 07, 2009, 08:40:11 AM »
Consider it done Eddy - i'll contact you when its out - how much of a hurry are you in?
« Reply #6 on: August 07, 2009, 11:20:37 AM »
Thanks Mezzmo
I have holidays in September - 19th through to the 25th and I'm planing to take the Kids to Brizvagas to do the theme park thing :D
The current engine we put in is running, but wont idel under 1000 rpm, on a high idle if you pulll the spark plug leads of on numbers 2 & 5 it doesnt change idle, on the others it does. I thought it might be plugs or points so I replaced them and it did improve things abit.
I think  I need to replace the dizzy cap coil and leads to see if that improves things - but the engine is an unkown so I could be waisting my time.
Either that or I bite the bullet and put in a VK fuel injected motor - but thats a whole other set of problems.
Offline matty
« Reply #7 on: August 07, 2009, 01:03:47 PM »
hey warren,
have you tried doing a compression test on the motor you have in there now, there not to expensive
to buy a compression tester and could save you spending on things you dont need. plus its a handy tool to have
especially when dealing with old and second hand motors.
just a thought
« Reply #8 on: August 07, 2009, 02:05:25 PM »
Hi Warren, i dont have an engine hoist etc but if you want the motor sooner your welcome to come round and rip it out - i've just removed the gas tank and strap so thats all there. Let me know what you want to do. The one thing i did forget is it has a spanking new (reco) starter as well. you lucky devil you!!!
« Reply #9 on: August 07, 2009, 05:53:29 PM »
Mezzmo
I have an engine hoist at the moment I will get back to you with when I can do it mate :D
Might need the master of engineswaps to help me - hey Eddy :D
