  • Dot Guests: 905
Author Topic: front stub axles  (Read 10011 times)
Offline wraithknight
  • love my bedfords
front stub axles
« on: July 27, 2009, 01:41:14 PM »
have put in ford xw disc brakes they fit fine aye bolt into the original wish bone ball joints
Im A Bedford Addict 18 and counting LMAO :)
Re: front stub axles
« Reply #1 on: July 27, 2009, 02:44:11 PM »
Do you mean you fitted XW Ford hubs/disks to the standard Bedford stub axle?
  • love my bedfords
« Reply #2 on: July 27, 2009, 03:28:19 PM »
no xw ford stub axle to convert to five stud ford patter
« Reply #3 on: July 27, 2009, 03:33:49 PM »
Ahh I see. So will you be using the XW brakes too?
  • love my bedfords
« Reply #4 on: July 27, 2009, 03:43:02 PM »
tea mate they bolt on and ive just got to get a new brake hose made  changing the brake booster to have an ld 28 in the van have modified the front head lights used 1980 toyota crown head lights twins so changes the whole look of the van wanted the five stud pattern so i can run 17'" or 19" mags
« Reply #5 on: July 28, 2009, 12:46:55 AM »
hey wraithknight will you have to modify tie rod end threads? or tie rod end tapers? what will yuo do there? cheers
« Reply #6 on: July 28, 2009, 01:08:46 PM »
WraithKnight
Got any pics of the conversion, as it could be a good conversion tip, may be heaps cheaper than the kits going around.
Did you use ford ball joints to go into the bedford wishbones ?
Now if you fit Transit power steering it may all just bolt up.
Offline hunterbynature
« Reply #7 on: July 28, 2009, 04:06:38 PM »
you would have to use the xw tie rod ends and adapt to the bedford rack, wouldn't you?
The Cheeky Kiwi
  • love my bedfords
« Reply #8 on: July 28, 2009, 04:23:46 PM »
gunna try have sum pic up soon guys got a bit on trying to get a job
« Reply #9 on: July 28, 2009, 05:29:50 PM »
Yes, but if you mount the transit power steering like some of the post on thi site suggest then it could be a simplw sweet conversion.
one of the dis advantages of the HQ conversion is that the discs have to be machined out to suit the bedford bearings, last time I went to a break place they were going to replace the discs, they were border line, but didn't because of the legalities of supplying modified discs.
If it is a sraight bolt on, then it opens up the option for adding the Powere steering, and a greater chioce and availabilty of custom rims
