  • Dot Guests: 1750
Author Topic: replacement ignition assembly  (Read 15732 times)
Offline johnb44
« on: March 05, 2016, 04:12:37 PM »
i have just fitted an ICE electronic ignition to my beast and while cranking I lost power the ignition assembly fell apart at the rear  :-[ what have you used to replace the assembly or over come the problem. thanks
jb
Re: replacement ignition assembly
« Reply #1 on: March 05, 2016, 10:11:15 PM »
Well it depends if you have a steering lock or not. If not, fit a new switch where the original one is, if not, try in the dash....or hidden somewhere. would make it even harder to steel!
Offline johnb44
« Reply #2 on: March 06, 2016, 07:39:39 AM »
thanks I do have the steering lock will see what the parts shops have today  ;)
Offline johnb44
« Reply #3 on: March 06, 2016, 04:26:18 PM »
i bought a narva 4 way ignition switch and made up a bracket to fit where the original one went a bit fiddly but worked ok sorry didn't take pics when I pull it apart again I will  8)
