  • Dot Guests: 521
Author Topic: What have you been up to this week  (Read 4439760 times)
« Reply #2000 on: September 07, 2013, 01:19:50 PM »
Hey Bas, are you going to keep the existing colour ?
« Reply #2001 on: September 07, 2013, 05:22:41 PM »
Gordon, think Black looks good , but Verena's not to keen, also like the colour of Davids ex van below, he said it vas a Silver base, as I will do a White base. but then when the time comes who knows...
Sorry forgot about the linking. Cheers
For some reason the Turbo mags look good on the van, they suit it...
« Last Edit: September 07, 2013, 07:16:17 PM by Bas / NZ »
« Reply #2002 on: September 07, 2013, 06:19:07 PM »
it doesn't allow linking from my site
« Reply #2003 on: September 07, 2013, 06:46:03 PM »
Yep, the stripe work gets my vote.
Offline shaginwagin
  • Real Vans are BIG Vans
« Reply #2004 on: September 11, 2013, 06:28:50 PM »
Last 2 weeks, the 253 came out, made up engine mounts for V6 and V6 sitting in it place.  :) :)  mock up engine mounts, even made up the engine mount with the air con bracket. use 186 rubber engine mounts and vn v6 gearbox mount grafted onto Gearbox cross member...  so will have a power steering and air con.   No I wont be making up the finished mounts had them done by a engineering place so I know they will be strong enough.    Now I have been grounded for a few weeks due to hernia operation and not allowed to lift anything heavy.   :(
Julian
Offline aussie
  • It's Buga owning a bedford
« Reply #2005 on: September 13, 2013, 07:16:53 AM »
Hi shagingwagon,
have you any photos, would like to know how big the cabin cut out is, is there any problem with over all lenth & angle in relation to tailsharft to diff.
Thanks Aussie Buga
aussie buga
« Reply #2006 on: September 13, 2013, 11:39:46 AM »
Hi Aussie, yes there are a few changes, when i did mine i had to get a shortened tail shaft made up, and the opening in the cab is a lot bigger. You will find the engine cover opening comes very close to the steering column where it goes through the floor. In your case the peddles may have to be modified. For me it was not a problem, as i don't have legs, so i don't use the peddles.
Offline shaginwagin
« Reply #2007 on: September 13, 2013, 09:24:49 PM »
Hi Aussie,  I have put up a couple of pics, in my gallery, but they are of  V8 out and V6 ready to go in and of the engine mounts that I made up to suit.  I also made up the passenger side  mount combined with Air Con bracket so it will have Air Con and Power steering.  Haven't got transit power steering unit yet but that is in the pipe line.
 No I am not using my engine mounts.  I just made up the proto type made sure they fitted and A/C pump fitted and in line for belt to run properly, need to get a slightly longer belt.  Had a local engineering firm make up the mounts saved some cash  by me making them up first.
 As I already had  the 8  in I  only had to trim out an inch or so to give enough clearance for the 6.
The 6 is in place have to take some pics of it in place and post them up as well... Using  the VN gear box mount and have had it grafted onto the beddie cross member, just have to get the man around to attach the cross member to the cross member brackets.
I've had a look at pics of Georges V6 mine seems to sit a bit higher, but cant get it any lower.  could  just be the pics though...
Have to get a new tailshaft made and angle between the gearbox and diff is not a major concern as long as they are in line.   More to follow, its only taken me 5 years so far but should/ will be going in a month or so.
Julian
« Reply #2008 on: October 05, 2013, 11:45:54 AM »
Well back on the Bedford carport / garage today making the expandable sides...
doesn't look like much, but will give me 1m extra.. but sill allow me to fold it away so the car can park there.
« Reply #2009 on: October 05, 2013, 12:56:13 PM »
Wow,
Thats an awsome idea Bas,
You can use them as shade, extend area to cover a motor,  etc
You should patent that idea mate,
Cheers marty
