  • Dot Guests: 775
Author Topic: A-Frame for towing a CF  (Read 6773 times)
Offline atk1
« on: September 25, 2013, 06:10:27 PM »
Hi guys, Im picking up my shell from the dip stripping place in the next couple of days and last night I thought I should build one of those A-Frame things like what the motorhome people use to tow their little runabouts behind them. Any ideas for good mounting points to connect to? It will be a lot lighter as it will only be the shell (no doors) with a front and rear end. No engine or trans. I like the idea of being able to move it around without the need of a trailer. Will those points behind where the bumpers go be strong enough? I will post some pics when I get to see it. Cheers
« Last Edit: September 25, 2013, 06:16:42 PM by atk1 »
Re: A-Frame for towing a CF
« Reply #1 on: September 26, 2013, 06:46:36 AM »
it would be the easiest place to tow from behind the bumpers but i would be inclined to weld another plate on top to strengthen it up before i was to do that.
good idea:)
i thought that was illegal in australia but it cant be if the motorhome guys are doing it?
« Reply #2 on: September 26, 2013, 07:44:59 AM »
If you're insured I'd check first as I'm sure they are illegal in NZ now too, your other option is a tow dolly
Offline atk1
« Reply #3 on: September 26, 2013, 04:43:01 PM »
Will look into it furthur but so far so good...
http://www.aa.co.nz/cars/ask-jack-forum/legal-advice/show/4314/
« Reply #4 on: September 26, 2013, 04:55:11 PM »
From what I have heard the A frame has to be certifyed & the towed vechicle has to be regoed all for insurance purposes I thik the only way is to trailer it or tilt tray I have friends hith motorhomes & they say it's all just too hard
« Reply #5 on: September 26, 2013, 05:46:02 PM »
For the small cost of a trailer hire or tilt lift, I wouldn't risk it.
Gross weight is over 2 tonnes, so even halving it  for what's been removed you are looking at over 1 tonne, and no extra brakes  :o
That's a huge extra strain on any vehicle.
Russell
