  • Dot Guests: 1027
Author Topic: mega rebuild in record time  (Read 35249 times)
Offline vuuup
Re: mega rebuild in record time
« Reply #30 on: August 21, 2013, 03:59:04 PM »
hey vanwolf, whats cross ribbing?
Offline VanWolf
« Reply #31 on: August 22, 2013, 07:30:45 AM »
After welding the grooved crack I ground a piece of the weld flat and I then welded a small piece of steel 5mm x 20mm at 900 across the original weld. Like a gusset.
Cheers.
Offline vuuup
« Reply #32 on: August 23, 2013, 09:30:07 AM »
sounds like a good idea, has it held up and do you have a photo?
Offline VanWolf
« Reply #33 on: August 23, 2013, 11:13:14 AM »
Have assembled the front end with engine and gearbox. Working on rusty windscreen surround.
Will post pics when I put it together.
Offline vuuup
« Reply #34 on: August 23, 2013, 06:32:46 PM »
thanks.
grill mod
Offline vuuup
« Reply #35 on: August 26, 2013, 09:00:19 AM »
had very worn out hinges, so this was a solution.
Offline vuuup
« Reply #36 on: August 26, 2013, 09:05:54 AM »
used 10mm sleeves of masonry bolts, and 8mm masonry bolt as pins. should be cheap if i need to re-sleeve ever again
Offline vuuup
« Reply #37 on: August 26, 2013, 09:09:13 AM »
and a bit off a taper and some washers... done. was going to recess the bolt but i am building a rat rod!
Offline vuuup
« Reply #38 on: August 26, 2013, 09:11:29 AM »
swivel bases, brackets, and hinges
Offline VanWolf
« Reply #39 on: August 26, 2013, 10:04:51 AM »
Vuuup,
Nice work!!! :) :) :) :) :) :)
