  • Dot Guests: 394
Custom Badges by BlackBedford
[April 29, 2026, 09:05:15 PM]
Author Topic: Just bought a flat bed bedford....what diff do they run???  (Read 10770 times)
Offline damo702002
Re: Just bought a flat bed bedford....what diff do they run???
« Reply #10 on: June 17, 2013, 09:57:08 PM »
hey rumax why did I need to multiply by 2 mate??????......I thought one roatation of the wheel to turns of shaft gave the correct ratio????.....am I missing something simple buddy?......but about 2.6 turns would be spot on for your calculations so I,m guessing your right,.....I,ll await your reply....thanks for taking time to help too.
« Reply #11 on: June 18, 2013, 05:27:31 PM »
basically, to quote Gordon "The wheel had to make two rotations. Ben made the point in his posting that you need to make sure that the jacked up wheel makes 2 rotations as it is essentially doing the work of two wheels" this is quoted from the diff section.  ??? Option B is to jack up 1 wheel, rotate it once, then lower it and jack up the other wheel and rotate once........ Now I have never heard of a diff with DIFFERENT RATIO's for each side, so just rotate ONE SIDE twice..... or multiply by 2  :D  Cheers Russell.
