  • Dot Guests: 690
Author Topic: Broken down  (Read 6548 times)
Offline THRILLS
Broken down
« on: December 28, 2012, 03:11:27 PM »
Hey Guys
Was driving my red 202 engine CF today - noticed what seemed to be a flat spot or a misfire a few times? Happened a few more times - then just broke down doing 100km.
Stopped on the side of the road an hour later it kicked back over and "just" made it home with the same flat spot / misfire feeling.
Any ideas? Would love some help before I take it to a mechanic
Re: Broken down
« Reply #1 on: December 28, 2012, 03:19:40 PM »
points or electronic ignition?
Offline THRILLS
Re: Broken down
« Reply #2 on: December 28, 2012, 03:34:51 PM »
Thanks mty, would electronic ignition affect the van whilst driving? Might check the points Cheers
Re: Broken down
« Reply #3 on: December 28, 2012, 03:49:11 PM »
sounds like the problem i had last year. new electronic ignition distributer and coil fixed it, no dramas since, :)
put a new set of points in it, or
if you can afford it change to electronic distributer and coil to suit,
http://www.ebay.com.au/itm/HOLDEN-electronic-distributor-138-149-161-179-186-202-come-with-bosch-coil-/261104227237?pt=AU_Car_Parts_Accessories&hash=item3ccb0653a5
if that link dosent work put this item number 261104227237    in an ebay search.
hope this helps fix your van, let us know how you go.?
cheers marty
« Last Edit: December 28, 2012, 03:51:38 PM by mty »
Offline THRILLS
Re: Broken down
« Reply #4 on: December 28, 2012, 04:07:46 PM »
Great Mty, gotta love Buga!!!
I just check out your link, thanks for sending it over - I'll give that a go.
Thanks
Re: Broken down
« Reply #5 on: December 28, 2012, 06:03:53 PM »
If you have a standard points setup it could also be a faulty condenser. Its worth replacing if you are going to do the points anyway.
Offline THRILLS
Re: Broken down
« Reply #6 on: December 28, 2012, 06:53:10 PM »
Ok thanks Gordon I will take a look at the condenser
Again, thanks for all the helpful tips!
Re: Broken down
« Reply #7 on: December 29, 2012, 12:31:03 PM »
I had a problem with plug wires shorting out on the engine cover Start the moter up at night & lift the bonnet & look for sparks jumping around near the disi I could hear them while driving around
Re: Broken down
« Reply #8 on: December 29, 2012, 04:24:42 PM »
hmmm does sound a bit "coily" to me,  ol futile done the same to me last year,  intermittant then just shat itself halfway between broken hill n home....
Re: Broken down
« Reply #9 on: January 01, 2013, 07:18:35 PM »
i would think its just be bad connections.. check earths. check wire running from chassis to the engine.
and all wires connected with the ignition system.
